I've searched these forums and tried a few of the options but the solutions are many years old, very contradictory (or just plain too techy for me to understand).
Can anyone tell me a simple way to convert/sync 29fps audio to 25fps video?
Results 1 to 10 of 10
If it's a simple case of PAL speed up -- speed up the audio from you9 29.97 fps video by a factor of 25*1001/24000 (~1.04271). But be aware that releases of movies in different countries are often different cuts. In which case you'll have to cut/paste the audio too.
^^ I've tried something like that before with Audacity but it seems to be guesswork as to how much to speed up or slow down the audio. I understand about different cuts for different countries, that's not a problem here.
Surely "changing the playback rate of the audio" can't be that difficult? I'm just looking for an easy to use app or even a guide on how to do it with a more complicated app would be nice. -
If that doesn't work then there is an issue other than the normal PAL speedup. Assuming there are no cuts or additions you can find a sound near the start of the video and a sound near the end of the video and scale accordingly. Keep in mine there may be an initial delay or advance that you have to account for.
Audio (video) conversion from 24 to 25fps
By Arbok in forum AudioReplies: 20Last Post: 20th Oct 2015, 18:01 -
Audio track from 25fps video with a 23.976 fps video
By cedworld in forum AudioReplies: 12Last Post: 22nd Apr 2014, 10:31 -
Using audio from 25fps source on 29.97fps video
By headless chicken in forum AudioReplies: 5Last Post: 26th Nov 2012, 07:14 -
Mac Command Line - Convert PAL 25fps to 23.976 w/audio sync?
By fmillion in forum MacReplies: 1Last Post: 16th Jul 2012, 20:07 -
is it possible to ivtc a 29fps ntsc source to 25fps xvid with gnot?
By iamtehsux in forum Newbie / General discussionsReplies: 65Last Post: 28th Dec 2010, 09:22
