I am using videostudio 11 plus and it first converts the DVD to a small vsp file. This file can then be placed in a edit system
OK how do I now convert/save to MPG or MP4
Apparently VideoStudio didn't help you learn much about video. DVD is already MPG. DVD isn't anything else. MPG is a lossy codec not designed foe editing. MP4 is a container, not a format, not a codec. but it can contain MPG encoded video if you insist. Otherwise, you have to re-encode MPG to another codec and take the quality loss.
Your VideoStudio must be pretty primitive software if it can't "edit" an MPG. Practically any lossy codec "editor" can work with MPG. Many of them make a mess of it, but that's you're concern not ours.Last edited by LMotlow; 4th Sep 2015 at 00:14.
- My sister Ann's brother -
Yep. It's that kind of day. What I get for writing VisualStudio apps for 12 years/60hrs/wk. Thanks for pointing that out.
What is a VSP file?
Files with the .vsp file extension are most commonly associated with the Corel VideoStudio slide show creation software. The VSP files are project files that have been created with the VideoStudio program. These files contain the slide show project data such as the video, audio and image references, movie timeline settings and slide show effects.
The .vsp file extension is also used for ClosetMaid Visual Storage Planner Design files, SPX sprite files and Virtusales ASP compiler project files.
So in your case it is a EDL or Edit Decision List that lists your edits and where your video and sound clips are stored. When you are finished you can use the VSP file to EXPORT your or maybe RENDER your handy work into a format that it supports. I would suggest you read the HELP file associated with the program.
Just a reminder a VSP file is NOT A VIDEOFILE it is simply a project file. So you don't convert it to video but rather use it to instruct your VideoStudio program to complete it's task.. When you save the small VSP file it means at anytime in the future opening this file will open up VideoStudio to where you left off edit waiting for you to make any changes or additions if required.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I will try that mp4 converter. In used handbrake and ended up with an mp4 about half the size of the original. Lost a bit of resolution as well.
For most editing I use final cut pro but this was for a dvd to video. I knew it was going to be low res but not this bad. The mp4 converter may be better.
How to use free program to convert avi/mpg/mp4 to DVD-R
By lovingit in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2014, 00:34 -
Deleteing audio from MP4 or MPG
By cottage in forum Video ConversionReplies: 2Last Post: 6th Nov 2013, 11:48 -
mp4 to mpg help needed..
By abao in forum Video ConversionReplies: 2Last Post: 12th Jul 2013, 07:28 -
MP4 bad, MPG OK?
By strudo76 in forum Video ConversionReplies: 11Last Post: 27th Dec 2012, 23:16 -
.mpg to mp4
By sc20k1 in forum Video ConversionReplies: 4Last Post: 16th Sep 2011, 09:43
