I took some old VHS tapes and used a small device to put them on my computer. They were put on the computer as VOB files. Each Vob file is only about 15 minutes long but is 1 GB in size. I want to be able to burn these videos onto a DVD but if I keep as Vob then i will only be able to fit about 1 hour worth of video in a dvd which is very little, and i will have to use way to many discs if i do it like this. So what is the best video format to covert to that will decrease the size without losing quality. Also the format needs to be easily burnable to a DVD.
Whatever the "small device" gave you IS a DVD:
https://www.videohelp.com/dvd#struct -
If they're only 1GB in size, you fit 4 of them on a DVD. You can put about 7 or 8 on a double-layer DVD.
DVD is MPEG. DVD can't be anything else. If you re-encode to a lower bitrate to reduce size, you will lower quality. There is no such thing as re-encoding and smaller bitrates without quality loss.
If you take a look at a DVD structure on DVD disc, you'll see that VOB's are always 1GB or less in size.Last edited by LMotlow; 3rd Sep 2015 at 16:01.
- My sister Ann's brother
Video losing quality
By nzcncf in forum Capturing and VCRReplies: 39Last Post: 29th Sep 2013, 18:57 -
Covert .VOB to AVI with out losing quality. How ?!
By SB4 in forum Video ConversionReplies: 7Last Post: 29th Feb 2012, 19:46 -
Best format to convert HD videos without losing quality?
By fabitos in forum Video ConversionReplies: 19Last Post: 4th Dec 2011, 00:22 -
Best compression program/format/codecs without losing quality
By adrian2055 in forum Video ConversionReplies: 12Last Post: 20th Jan 2011, 16:29 -
Covert a .mp4 movie's audio alone to mp3 without changing the video quality
By ckarvnd in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 12:02
