I recently purchased a nanny cam type camera, that both streams video via wifi to my computer, and will record on a microSD card in the camera. When I went to download the SD card and play the videos (it records in blocks of time 1 hour long), they would not play in Windows media player (missing codec). Next I tried VLC, and the videos play, but will not FF or seek - you just have to watch from beginning to end. If you try to skip ahead, it just throws you back to the beginning. Is there an easy way to make the ASF file seekable?? I have looked into this on the web but every option has either not worked or is too technical for me. Looking to ideally input the file, hit a couple of buttons, and output a seekable file.
Thanks!
Results 1 to 30 of 31
If it's "fixable" just importing and exporting will usually fix it
You can also try forcing an index in the advanced options
Also open the file with mediainfoxp => view => text and copy and past back the info. Not all asf files are WMV type, sometimes you can get other bizzare variants -
This is what I got:
General
Complete name : E:\IPCamera-150903-023453-P.asf
Format : Windows Media
File size : 729 MiB
Duration : 22mn 6s
Overall bit rate : 4 610 Kbps
Maximum Overall bit rate : 3 076 Kbps
Encoded date : UTC 2015-09-02 18:34:53.000
Video
Format : AVC
Codec ID : h264
Description of the codec : h264
Bit rate : 4 387 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Audio
Format : ADPCM
Codec ID : 11
Codec ID/Hint : Intel
Description of the codec : IMA_ADPCM
Duration : 22mn 6s
Bit rate : 32.0 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 4 bits
Stream size : 5.06 MiB (1%) -
It uses h264/avc, not wmv type video
I would try re-wrapping it into a different container
e.g. load into virtualdub, video=> direct stream copy, audio=> direct stream copy, file=>save as AVI . You might need an h264/avc VFW decoder installed like FFDSHOW
Or try rewrapping with ffmpeg into a MP4 or MKV container
eg.
ffmpeg -i input.asf -c:v copy -c:a copy output.mkv -
Thanks, I'll give it a try soon. I'm hoping these programs are used-friendly (?), I'm not very tech-savy.
OK, so Virtualdub doesn't seem to accept ASF files and ffmpeg I have no clue about. Getting desperate, and advice? How do I get an ASF file to be seekable? There's got to be a way to do this that doesn't require a Ph.D
You don't have a typical "ASF", which usually uses WMV compression . So no, there is no easy way - that's probably why asfbin didn't work
Vdub is probably the next easiest way that has some chance of working, but you need to download the WMV /ASF plugin to be able to load ASF into vdub
When you click on the vdub hotlink, scroll down and there will be links to various import plugins
https://www.videohelp.com/software/Virtualdub
here is the one for ASF/WMV
http://gral.y0.pl/~fcchandler/Plugins/WMV/ -
I suspect it's re-encoding the file. When you re-encode the file, you can place keyframes anywhere and it will seek properly, but you will lose some quality using lossy compression . Those other suggestions were attempting to "re-wrap" the file, to put it into another container. This might not work, but there is no quality loss and the process should be faster
Yes definitely noticed a quality reduction, and file sizes are 30-40% smaller. Another side effect is that some videos play normally but others play at fast speed...all collected with the same camera. Cant figure that out. Ill try the other methods,
mkvmerge does not support wmv/asf input.
I suggest you learn how to use ffmpeg from the command-line. It is not that hard, really. You can download it here:
http://ffmpeg.zeranoe.com/builds/
If you are unsure which version you need download the 32 bit "Static" one. Extract it and copy "ffmpeg.exe" from the "bin" folder to the folder of your asf file. In Windows' explorer hold the left shift key on your keyboard, right-click into the folder and then click "Open Command Window here". Then simply copy and paste the command line examples we have given you and hit enter. ffmpeg should do its work then. (Just replace "input.asf" with the name of your file).
Example in addition to the ones already suggested:
ffmpeg -i "input.asf" -c:v copy -c:a flac "output.mkv"
(this will convert audio losslessly to a more compatible format since I don't know if ADPCM in mkv is supported by ffmpeg or vlc) -
The video is h264,not wmv so it should be able to open it.
you can use program AnotherGUI
set ffmpeg.exe location in preferences,
drag and drop files, select preset ffmpeg: Copy codecs into mp4 container and click Go -
It's a batch command. It will process all the .asf files in a directory (that is what the *.asf is for)
Wow this is frustrating... Ok so it seems that ffmpeg does work great on the first video of the series (as I explained this camera records in user defined blocks of time of up to a max of 60 minutes, so there are multiple files in a day if recording all day), and in one case the second. However for most other video files for a day, the ffmpeg output keeps repeating "starting new cluster due to time stamp" followed by a few lines of "invalid dropping". The video seems to be stuck at the last frame and doesn't play.
I appreciate the help. Potplayer does play the videos and seek, but it seems to be having a really hard time with the longer videos. When seeking to a further point in a video it takes a LONG time for it to catch up an play from that point, and sometimes does it in really slow or fast motion. Still not an efficient way to skip thru a vid quickly to get an overview.
On the small sample, if you demux and remux it works in all players. But the timing might be an issue. Part of the issue is the timing in the original file, the timecodes are messed up. It's probably like that for all the files that have problems. It might have to do with your device buffering before it records. If you demux and remux the audio/video streams, you get rid of the pre-existing timecodes and assume a new frame rate when you remux them into a new container - but the timing might be slightly off - so if timing for events or audio sync is critical, it's not going to be a good option
And you can re-encode all of them as a last resort (you tried that already) . It's slower, and you lose quality if you use a lossy method -
You can demux / remux it with ffmpeg, or if you want you can use something else to remux like mkvmerge
Try it out on one of the longer problematic files. The timing will be off - the timecodes in the original are very variable, while this assumes a constant frame rate. But if you use the old timecodes, the timing is off too. It might be a problem with reading the timecodes - I used a program called wmvtimes to extract them
Code:ffmpeg -i IPCamera-150909-185559-P.asf -c:v copy -an vid1.h264 -vn -c:a copy aud1.wav ffmpeg -r 25 -f h264 -i vid1.h264 -i aud1.wav -c:v copy -c:a copy r25.mkv
Virtualdub: "error while seeking file" (please enter **** only)
By marcorocchini in forum Newbie / General discussionsReplies: 5Last Post: 25th Aug 2014, 10:12 -
Need help playing .asf file
By jerecho in forum Software PlayingReplies: 6Last Post: 11th Mar 2013, 21:01 -
How can I convert ASF file?
By QuattroNN in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2011, 13:11 -
.asf file will not open
By powrslave in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:56 -
asf file audio sync issue
By andy99 in forum AudioReplies: 4Last Post: 20th Jan 2011, 19:41
