I have a large collection of files from a surveillance system that contain a metadata overlay typical of surveillance systems, i.e. time, date, camera name, etc. The subtitles will display in VLC by simply turning on 'Track 1 (English)' in VLC's 'Subtitles' menu. According to VLC, the subtitles use the tx3g codec.
The subtitles will also display in Quicktime, although they're tiny and I haven't been able to enlarge them to a useful size.
My ultimate wish is to be able to have the subtitles show up in Premiere Pro, since that's where I'd like to do any cutting, clarification, etc. of the videos. But I've tried everything I can possibly see to get the subtitles to show up and they still don't.
I've also tried tools I found discussed here on VH, including gMKVextract, MKVCleaver, MP4box, MKVToolnix, etc. All with no success.
Given that these titles display without a hitch in VLC and at least display (even if tiny) in Quicktime, surely there's a way to get this info extracted/converted/whatever into something I can use in Premiere Pro. Anyone have ANY ideas to share?
Huge TIA!
Chop
Results 1 to 9 of 9
If you can toggle them on/off, then they are essentially text subs (quicktime timed text). You should be able to extract them with quicktime pro, or ffmpeg, possibly CCExtractor
Text subs don't really have a "size" - it ultimately depends on the renderer settings and method of displaying them.
They won't display in PP, but there are ways to render them in the fashion/font/size that you want and hardcode them onto a transparent overlay for import into PP
If you still can't extract them, then post a small sample videoLast edited by poisondeathray; 1st Sep 2015 at 14:07.
@poisondeathray : Got them extracted via Quicktime Pro. Plain text format. What do you suggest as a workflow for rendering them as a transparent overlay?
There are slightly different tx3g/ ttxt formats . You might have to make some minor adjustments to get it working
I've posted step by step instructions before on the basic workflow . It's not specific to PP, you can use it to import into any editor. It uses avisynth with masksub() and a RGBA codec like lagarith, or ut video (ie. one that supports alpha channel)
Here are a few of the posts:
https://forum.videohelp.com/threads/364265-Importing-SRT-subtitles-into-Premiere-Pro-CC...00#post2319000
https://forum.videohelp.com/threads/356192-How-to-add-in-Sony-Vegas-Pro-11-ass-srt-subs
You can convert the subs to ASS subs in aegisub to get almost ANY formatting. ASS subs support basically everything, even fancy effects. -
Someone mentioned 3rd party plugins for PP - EZtitles and SugarFX - I haven't tried those, but if you're going to be doing lots of these it might be worth checking it out instead of having to render out a hardcoded/tranparent video for each one
https://forum.videohelp.com/threads/364265-Importing-SRT-subtitles-into-Premiere-Pro-CC -
I used MP4Box, and My MP4GUI to use it in windows environment. You just look for the mp4 file and it will show you what the container includes, there will be a pop up window which tells you there is a txt stream, dont know why it appears, but is the first thing that shows up after selecting the file. Then all you have to do is go to the Demux tab and check the box in the "Text - Timed text" named option and click the Demux button. It will appear in the same folder where the mp4 file is located, and it will be extracted in .srt format. Hope this helps even when its a 5 year old question.
Using MP4Box on the command line on a Mac:
- Get the info about the mp4:
% mp4box -info mymovie.mp4
Look for the TrackID of the sbtl:tx3g subtitle. Once you have that number, e.g. 3:
% mp4box -srt 3 mymovie.mp4
This will create a file mymovie_3_text.srt
Bingo!
Does anyone know how to extract subtitles from .ts?
By ALUOp in forum DVB / IPTVReplies: 48Last Post: 27th Jul 2022, 01:39 -
How to extract subtitles from a Blu-ray and convert to srt or sub/idx
By Baldrick in forum User guidesReplies: 35Last Post: 6th Dec 2021, 08:00 -
What can I use to extract/convert subtitles from DVD?
By Joshray in forum DVD RippingReplies: 9Last Post: 22nd Dec 2012, 13:33 -
How to extract subtitles from MKV videos to convert them to AVI
By zikegi in forum Video ConversionReplies: 0Last Post: 15th Sep 2011, 21:47 -
Extract subtitles from .ts
By anchonio in forum DVB / IPTVReplies: 9Last Post: 16th Apr 2011, 05:07
