I found this post online. Just wondering if it would be a good method of converting a 50fps project to 25fps in preparation for a DVD.
'You can do this by layering two adjacent frames above each other in a 25fps sequence.
1) Create two 50fps sequences of the clip (A and B).
2) In one of the 50fps sequences, trim the first frame and slide the clip to frame zero.
3) Create a 25fps sequence and nest the two 50fps sequences above each over.
4) Reduce the opacity of the upper sequence so that both clips appear. In this example the upper clip is set to 50% opacity.'
Not a good method for general use (you wouldn't use it for everything, maybe only selected sections). It causes blurry (ghosted) images
Bd Rebuilder ,Can convert 1080p 50fps to 25fps?
By ningnong132 in forum Video ConversionReplies: 12Last Post: 14th May 2014, 12:58 -
using avisynth to convert 50fps to 25fps
By codemaster in forum Video ConversionReplies: 3Last Post: 15th Aug 2013, 18:11 -
Converting a 50fps 720p h264 video into dvd pal 25fps
By Joep97 in forum Video ConversionReplies: 4Last Post: 12th Jul 2013, 13:17 -
AVer MediaCenter saves video at 50fps when there ment to be 25fps
By jamespoo in forum DVB / IPTVReplies: 1Last Post: 17th Jun 2011, 03:39 -
Recorded TS file change to 25fps instead of keeping it to 50fps in mkv.
By Dazzler1985 in forum Video ConversionReplies: 1Last Post: 18th Apr 2011, 18:01
