Results 1 to 11 of 11
  1. I've been sent a VIDEO_TS folder and I'd like to burn it to DVD without converting / re-encoding. Thanks!
  2. Member DB83's Avatar
    Jul 2007
    The only program I know of specifically for a Mac is Toast.
    Most Mac users would add a Windows partition and dual-boot. Then possible to use free tools such as imgburn.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Moved the thread to the mac forum where you can get more help.
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Try this app called Burn.
    Basic, but does just what you needs now.
  5. Does BURN burn the TS-folders AND create the menues or will it re-encode again?
  6. I'm a Super Moderator johns0's Avatar
    canada
    It just burns the folders,similar to imgburn.
  7. So, he will have a data disc with TS-folders, but no DVD that is playable in a standalone DVD player (like with a menu etc.), right?
    I am unsure, if he wanted to know how to make a data disc or a playable DVD.
    For example, if BURN gets DVD conform mpeg2 that has been created by Avidemux, it doesn't just add the tables, menues and folder structure, but it re-encodes it to mpeg2 a second time (this time in a TS_folder). As far as I know.
    Toast makes playable DVDs out of TS_folders. Old versions are found cheap on Ebay. (In fact in Toast, you can select "video DVD" and then decide between "DVD (for standalone players), VCD, SVCD, DVD from TS_folders (for standalone players)". Toast has the better picture quality than Burn I was told in the applediscussions forum.
    Aug 2006
    Authoring (creating files and folders for a playable DVD, including menus) and burning (putting the files and folders on a DVD using the correct file systems and locations) are often done as separate steps performed by different programs.
    If given the required DVD files in a VIDEO_TS folder, surely Burn knows how to put them on a DVD to create a DVD video disc, although it apparently can author DVDs as well.
  9. Originally Posted by usually_quiet View Post
    I tried Burn and it doesn't take the DVD conform Mpeg2-PS that Avidemux had created and I was told that naming a folder TS_video would change nothing.
    So, you actually have to have TS_folders. I wonder if they are "ripped" from another DVD, then he could have just made an image/copy (either with disk utility or the incremented "burn" function of OS X, if you don't want to pay for Toast). I would really like to know, myself, what Mac App can create TS_folders out of a given non conform source material.
    @OP
    what App did you use for that?
    Aug 2006
    Of course it won't change anything. Burn would need to author that Mpeg2-PS from Avidemux, which would create DVD files (VOBs, IFOs, and BUPs) containing the menus, video stream, audio streams, subtitle streams, and playback instructions inside a VIDEO_TS folder.
    Burn can apparently author a basic DVD from at least some non-complaint sources. http://www.creativetechs.com/iq/easily_burn_movies_to_a_dvd_without_apples_idvd.html
    Burn may work with compliant sources too, but it could re-encode again
    However, someone gave the OP for this thread a VIDEO_TS folder containing VOB, IFO, and BUP files. The folder could be from a DVD rip or it could be something the giver authored himself/herself. According to Case, who does know something about working with video on a Mac, Burn can create a DVD video disc from an a VIDEO_TS folder. Burn probably creates a DVD ISO from the VIDEO_TS and burns the ISO to create a DVD video disc.
  11. Originally Posted by usually_quiet View Post
    Burn may work with compliant sources too, but it could re-encode again.
    I had found the creativecow article, too. It does convert AVC for example (if I remember correctly from my Tests), but it doesn't like the Mpeg2-PS file of Avidemux, it would even show it greyed out, when you to select it from the finder from the burn menue.
