Can you save your menu templates? Getting tired of having to change everything back and forth every time I switch between projects.
Go to subtitle/audio tab,the setting are there for text positions.They are saved as soon as you apply them.
Another question, is it possible to select which chapter thumbnail images are used in the background of the classic title list menu or is it just completely random?
Multiavchd Title List Menu Question
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 1st Aug 2015, 19:10 -
question about avchdcoder and multiavchd
By rotatorkuf in forum Authoring (Blu-ray)Replies: 7Last Post: 17th Apr 2014, 14:36 -
Newb question for multiAVCHD...
By calgunner in forum Authoring (Blu-ray)Replies: 6Last Post: 10th May 2012, 12:12 -
multiavchd menu question
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 12:12 -
Multiavchd question about blueray output folder compliant validation
By lutinor in forum Authoring (Blu-ray)Replies: 0Last Post: 29th Mar 2011, 03:55
