Since I already have to extract the audio from the DivX AVI before authoring a DVD with DVDit, why don't I just go ahead and convert it to Dolby Digital format, which is what DVDit uses for compression. That way, DVDit won't have to compress it... it would save me a step.
Am I on the right track with this thinking.. can it be done? How? I haven't found any toold that would extract audio from DivX AVI and re-encode directly to Dolby Digital. Sort of the way VirtualDub goes decompresses the audio from the DivX AVIs and puts into uncompressed WAV.
That sounds right, I have heard that Sonic Foundry's soft encode can rpoduce dolby AC3 from various input files. However, knowing how good DVDit is, it wouldnt surprise me to see it re-encode the audio anyway!
Dolby Digital Audio bit depth = 16 bits??? Why?
By Bonie81 in forum AudioReplies: 6Last Post: 12th Jun 2011, 22:44 -
Synchronization Probelm with Dolby Digital EX Audio, Help!!
By caesarhawy in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2009, 09:35 -
Home Theater in a box audio- No Dolby Digital?
By PhoneMatt in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2008, 16:34 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54
