This may seem like a stupid question but does converting an interlaced video to 50fps give a smoother framerate? An interlaced video has 25 frames per second. I convert it to 50fps. I can see in a video editor that is has 50 unique frames (no duplicated frames). So does this mean the video will have a smoother framerate than the 25fps original or will it just look as smooth as the original did?
Each frame of the 25 fps interlaced source contains two half pictures (fields). When properly displayed you see those two half picture separately and sequentially at 50 fields per second -- essentially a real time bob deinterlace. So no, deinterlacing yourself to 50 fps does not make the video smoother. If your player doesn't bob then doing so yourself will give smoother playback.
Converting 25 fps slowmo video to 50fps HFR video
By koffish in forum Video ConversionReplies: 1Last Post: 24th Apr 2015, 03:04 -
Target framerate for converting a video from 1080i
By Knocks in forum Video ConversionReplies: 12Last Post: 26th Jan 2015, 11:29 -
Converting a 50fps 720p h264 video into dvd pal 25fps
By Joep97 in forum Video ConversionReplies: 4Last Post: 12th Jul 2013, 13:17 -
Problem with converting .mts 1080 50i and keeping it 50fps
By gf3user in forum Video ConversionReplies: 10Last Post: 23rd Nov 2011, 09:43 -
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05
