Is there anyway to encode a movie to MPEG-2 losslessly? I don't care if it takes up 90 GB, I just need it encoded to MPEG-2 losslessly. Preferably using CCE.
No, that is not possible because the algorithm used to compress the video is based on tosing information that is not needed, or is repeated.
However, using a bit rate of 15Mb/sec or higher on 720x480 video, you will not see any difference in quality unless you go frame by frame and look for artifacts.
Network TV use mpeg-2 for server storage and satellite transmission of network programming. The bit rate of these mpeg-2 programs will be in the 8-16Mb/sec range. The station I work for use 8Mb/sec for all TV programs on the server. If you need to save the program for editing, than I would suggest mjpeg for easy editing, and up to lossless compression. 50Mb/sec mjpeg would be professional editing quality video.
Cannot compare lossless with MPEG-2 encodes: Frames aren't lining up!
By Mini-Me in forum Video ConversionReplies: 15Last Post: 5th Dec 2010, 01:08 -
lossless cropping?
By hardy in forum DVD RippingReplies: 23Last Post: 13th Nov 2010, 07:11 -
Are all decrypters lossless?
By sldvd in forum Newbie / General discussionsReplies: 2Last Post: 28th Mar 2010, 23:43 -
lossless editing MPEG-2 (*.mpg) with trimming and appending with preview?
By Andy Gone in forum EditingReplies: 8Last Post: 3rd Sep 2008, 06:49 -
Lossless editing of .m2t (MPEG-2 TS) in Avisynth
By Tigon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th May 2007, 08:23
