hi,
i have a video file whose extension is MP4.
The video codec is H264
The audio codec is MP2
i wish to rencode the audio part ONLY without touching/recoding the video part.
how can i do that ?
i am familliar with MKVtoolNix but it only works on .MKV file where you can add/extract audio track how we went.
is there any MP4toolNix alike software to do that ?
thanks for help or advice
Best Regards
Mike
XmediaRecode. Set Video= copy and Audio= re-encode.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
And yet another options: MediaCoder. Besides doing a Copy for the video part you can disable it altogether just making an audio track.
mp4box. It's a little more complicated because there is no UI, it's a cmd tool.
Here's an e.g. on how to extract an audio track from .mp4
But first you need to know the index of the track if you want to extract it.
In mp4, index starts from 1 but in mkv it starts at 0 (Just a by the way).
Also you need to know the codec to know it's extension, Download MediaInfo, it's awesome.
mp4box infile -raw trackid:output="outfile.*"
As for encoding, search for audiocoder. I used it in the past, I'm not sure of the programs current state though.
To add back to mp4 file (I recommend you create a duplicate cause this is permanent, in case you make a mistake):
mp4box file -rem trackid -add "file":name=""
Good luck !!Last edited by Shaylen; 23rd Feb 2016 at 07:13.
Editing an audio track in an Mp4 video WITHOUT video data loss ?
By PeteV in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2014, 14:46 -
Fixing Audio track synchronization in a .mkv video file
By budw16 in forum AudioReplies: 1Last Post: 21st Jul 2013, 18:22 -
Making an MP4 video with audio track only
By BladePoint in forum EditingReplies: 12Last Post: 4th Feb 2013, 22:29 -
Re-encode audio but keep video the same in MKV file
By V879 in forum Video ConversionReplies: 3Last Post: 15th Apr 2012, 08:51 -
Trying to encode the video file from f4v to mp4 for mobile devices
By timurka in forum Portable VideoReplies: 1Last Post: 26th Jan 2012, 21:17
