A friend who has professional encoding software is going to encode some footage for me to MPEG2 DVD. I have a HD timeline in Premiere Pro and I'm just wondering if I should export uncompressed HD or uncompressed SD, to give them to encode? Note: the reason they are encoding for me is because Premiere Pro did not do a good enough job at encoding to mpeg2.
Ask your friend what s/he prefers
But if it's interlaced HD, definitely do NOT do it in PP. Very poor interlaced scaling -
Yes they can - there are many different scaling algorithms available. Even within PP, you have a few choices (e.g. when MRQ is on with CUDA it uses modified lanczos2 + bicubic lowpass, but uses bicubic only when CPU only is used ) . Some resizers are sharper than others - which might be good in some situations but bad in others. For example , if the source footage was "soft" , a sharper resizer might be appropriate. If it was typical HD footage, a "sharp" resizer would usually be a bad idea for DVD
But preparing for a DVD, even progressive, might include a few other steps like lowpassing, denoising certain sections, filtering others- Your friend should be able to provide any instructions if they want something else done -
No information on the format of your source, other than it HD progressive. DVD is usually (note, usually, not always) interlaced at 29.97i NTSC or 25i PAL. If the HD matreial is progressive and runs at 60p as many HD camera videos do, you'll have to interlace after downscaling. DVD can't be encoded for anything other than 29.97 or 25 fps.
- My sister Ann's brother
capturing scale ratio issue
By zoranb in forum Capturing and VCRReplies: 44Last Post: 30th Sep 2014, 12:40 -
Video Resizeng in Small Scale
By kotuwa in forum Video ConversionReplies: 9Last Post: 1st Sep 2014, 07:18 -
Is There an Evaluation Scale for SVRT?
By Teta in forum Video ConversionReplies: 9Last Post: 6th Apr 2014, 07:07 -
Scale up a video?
By CrazyMLC in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2012, 23:30 -
Why do some of my conversions scale on my display, others don't?
By tonyp2 in forum Video ConversionReplies: 12Last Post: 10th Sep 2010, 06:24
