hi, everyone, i have a 20 gig video file that I need to cut into 4 segments to store on DVD. My cutters fail to handle this size file. Does anyone have a solution for me? thanks
what format?
You could place inside an RAR archive using whatever compression tool that you use.
You could also use a file splitter such as HJSplit.
If you intend to make this a habit, I'd recommend investing in a Blu-Ray burner. Having said that, I'd personally just use a HDD.Google is your Friend -
MKVMergeGUI can split MKVs. MyMP4BoxGUI can split MP4s. TS Muxer can split TS/M2TS files.
- My sister Ann's brother
How long downloaded Youtube mp4 video can I fit to a 4.7 GB DVD
By newripper in forum Authoring (DVD)Replies: 4Last Post: 22nd Feb 2015, 11:34 -
Cut part from video and cut subtitles as well
By aapje in forum Video ConversionReplies: 7Last Post: 8th Feb 2014, 11:11 -
Editing a video to fit on DVD?
By Denv12 in forum EditingReplies: 10Last Post: 10th Sep 2013, 23:20 -
Is there a tool can convert video and compress and burn it to fit a DVD?
By coody in forum Video ConversionReplies: 6Last Post: 18th Feb 2013, 12:58 -
I have a 4hr mpeg 2 video and i need to fit it into a 4gb dvd-r
By missyfy in forum Authoring (DVD)Replies: 4Last Post: 3rd Feb 2011, 05:12
