Hi,
I'm trying to figure out the quickest and easiest and most native way to get video off an HD camcorder, either AVCHD or .mp4, do some simple trimming, and then end up with a final video for sharing via dropbox, DVD, or blu-ray, and the video must retain the date and timestamp.
The only options I can think of are
- using iMovie, which could display the timestamp but may take forever doing multiple conversions and/or reduce resolution down from HD to the 920 x 540 or whatever it wants you to do. (Macbook Pro laptop).
- using an Elgato Game Capture HD to capture playback directly from the camcorder and then using the elgato software to make the simple trims/cuts.
Does anyone have any idea which of these methods would work best, if at all, or if there is a better method?
Thank you,
Results 1 to 1 of 1
Reading .MTS file date and timestamp
By avid in forum ProgrammingReplies: 0Last Post: 2nd Sep 2014, 06:56 -
How can I add a running date/timestamp to a video? (hh:mm:ss format)
By quantice in forum Newbie / General discussionsReplies: 3Last Post: 19th Mar 2012, 11:34 -
Best way to go from AVCHD, date/timestamp it, and save as Mpeg 2.
By pf4711 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Feb 2012, 15:07 -
How to store/preserve very seldom used camcorder
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Aug 2011, 12:18 -
Date & Time capture of DV using Enosoft DV Processor
By nharikrishna in forum Capturing and VCRReplies: 3Last Post: 17th Jan 2011, 16:07
