Hello!
First of all,sorry my bad English...I need to learn more.
I recorded my videos to a Samsung S2 Portable 3.0 External Hard Drive.I use Sony Vegas Pro 11 for editing,and when I'm try import .avi video(s),then Vegas is freeze.When I try copy to my computer it write:"Cannot read from source file or disk".When i try to open it,i got a error massage:"Bad file descriptor".
I realized what happend...my External Hard Drive prefer a USB 3.0 port,but my computer is not a new one,therefore i only have USB 2.0 port(s),and transmission was slow and probably that is a problem.
My question is,How can i repair my videos?
Kex
Using a USB 2.0 connection, or even a USB 1.1 connection isn't likely to cause those type of data transfer problems. USB 3.0 is backwards compatible.
But I would never plug an external HDD into a USB hub as that could cause problems.
I would check the USB connections and if the USB HDD has a separate power supply, use that.
You could also try updating your existing USB drivers in your PC and try using different USB ports.
To repair it, you need to try to recover the damaged file, maybe using something like ISOBuster.
And welcome to our forums.
CRC errors indicate bad sectors on the hard drive, not a problem with the AVI files, per se. I would run CHKDSK on the drive with a full scan and error repair. After that copy whatever you can off the drive to another. Then retire the drive, or maybe use it as temporary storage for non-critical files.
A USB hub would be an extension from a USB port. Sometimes externally powered or not.
For most devices it's better to be plugged directly into a USB port.
And on a desktop computer, all ports may not be the same. My main PC has a couple of USB controllers on board.
It never hurts to try a different port if you are having problems. With laptops, probably only one controller unless it also has USB 3.0.
VirtualDub error: Video Compressor error: The source image format is not
By maddie in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2015, 12:12 -
Interface CRC Error Count
By kyrcy in forum ComputerReplies: 2Last Post: 22nd Oct 2014, 10:22 -
VirtualDub Error - Video Compression Error
By showsnsdespa in forum Video ConversionReplies: 11Last Post: 16th Jan 2014, 15:05 -
CRC Errors in Blu-ray burns...
By Lathe in forum Blu-ray RippingReplies: 12Last Post: 13th Dec 2010, 00:28 -
Crc error
By Hell Bound in forum DVD RippingReplies: 6Last Post: 6th Nov 2010, 07:00
