    Oct 2008
    Hello
    Can anyone please explain how i go about removing the borders and converting the video file back into a PAL 16.9 DVD file size video?
    https://www.youtube.com/watch?v=-XQeR16psPw
    If anyone could give me a kind of tutorial i be most grateful.
    Most converters can crop. You can try AVSTODVD. I think it has a visual cropping editor now also.
    Jan 2007
    that is called 'cropping' not un-cropping
    you want to remove the black borders , there fore you Are cropping the video frame
    there is no such thing as un-cropping
    if you take a picture or video frame and remove info from the sides or top/bottom to change its ratio
    there is no way to restore the missing data
    when a video frame has been padded on sides or top/bottom to change is display ratio
    the padding can be cut away thats called cropping
    the only problem is each time something is padded or cropped it is re-encoded which causes some quality loss
  4. Member Cornucopia's Avatar
    Very minor, rare exception: when cropping exists as metadata. Then you can adjust or remove it.
    Oct 2008
    Thanks all for the replies.
