Hi there
Could someone please show me a way of preferably being able to keep all files intact (without having to re encode and losing quality) of removing certain audio languages from some ripped DVD files?
I would still like the same file layout with all IFO VOB files but just to remove a particular audio language if possible?
Thank you.
Results 1 to 11 of 11
Have you tried the old dvd shrink? You can disable shrinking and just remove audio tracks.
Job done then thanks guys
Can you suggest a particular version to go for please? -
Are you able to help me locate the old version though which means I won't have to shrink the files?
I can't seem to find it on the VH download section. All I can find it version 3.2.
Thanks for your reply. -
Sorry just another question before i start this....
How would I remove the DVD menu completely in DVD Shrink?
Is this even possible? -
Select the option to Re-author.
http://www.dvdshrink.info/reauthor_basic.phpThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
Removing audio streams from VOB files.
By dominique120 in forum Newbie / General discussionsReplies: 8Last Post: 17th Jul 2014, 00:24 -
Removing Unwanted Audio Portions From a Video Clip
By D.V. Dee in forum AudioReplies: 3Last Post: 6th Apr 2014, 11:17 -
help needed to download video with 2 languages
By yogi7 in forum Video Streaming DownloadingReplies: 3Last Post: 24th Dec 2012, 10:19 -
Removing unwanted scene from a MP4 Video
By w11x22 in forum EditingReplies: 2Last Post: 14th Sep 2012, 14:07 -
Removing unwanted object from a Video file
By truth of life in forum EditingReplies: 11Last Post: 30th Mar 2012, 09:21
