    May 2010
    pakistan
    In this video in centre there is ablinking line.How ican remove it after downloading from youtube. Link is as under
    https://www.youtube.com/watch?v=2YWIX2cKV_E
    USA
    It looks like a bad VHS transfer to a digital format.
    The noise at the bottom could be VHS head switching noise and could be cropped out or replaced with a black line.
    The picture breakup in the center you can't fix, AFAIK.
    I would try to find another source for the video.
  3. +1 for Redwudz's suggestion. Looks like dropout compensation working overtime on either a damaged tape or worn out heads. Start over.
  4. You can try covering the tracking noise with a delogo filter but the result will probably be worse than the source.
