I know this isn't an actual video question, but it's to do with video capture software.
Basically, AVermedia RECentral can capture to a separate MP3 file during recording. I've been doing this since I got the Live Gamer Portable, and it works a treat. Usually, I use a USB Microsoft headset with a mic to capture my commentary.... no problems, always works.
I also sometimes use a USB Logitech webcam as a mic, if I need to record co-op gameplay. I've only done this once, and that time it worked. It created a separate MP3 file of our commentary. However, THIS time, today... I recorded some co-op footage, and found out that it DIDN'T record a separate MP3 file.
Everything is set up in RECentral just as it always was, with the webcam mic being selected. It still works fine with the headset. I tested the webcam mic with a separate audio recorder and it worked, so it's working fine OUTSIDE of RECentral. But no matter what I do, when the webcam is the selected mic, I get no separate MP3.
While this isn't a HUGE problem, and I can still do it the way I used to (with a separate audio recorder and a sync method) it was just easier this way.
Does anyone with RECentral experience have a clue??
I use the Avermedia RECentral software and try to record the audio separately but sometimes when I record the audio is delayed with the audio of the game. Can someone help me? I use a USB microphone chat lx3000 life.
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 234Last Post: 31st Dec 2025, 19:15 -
Converting Multiple Files Into Separate Files
By ashes17 in forum Video ConversionReplies: 1Last Post: 15th Aug 2013, 01:22 -
How to splice together separate 5.1 .wav audio files??
By JetrellFo69 in forum AudioReplies: 3Last Post: 23rd Dec 2012, 17:13 -
Copying separate files from dvd's
By Peter1954 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Dec 2011, 08:15 -
.mkv file with separate audio files
By fabpozzi in forum Video ConversionReplies: 3Last Post: 20th Jan 2011, 23:19
