So I got the PVR a couple days ago and finally had time to set it up to capture. Downloaded all the drivers and even power cycled it like the instructions said to reset the firmware.
The problem is that, even though I get video and audio in the capture utility, I only get picture on my TV. Without the HD PVR, the sound comes through like normal, so it's not the HDMI cable and it's not HDCP.
Is there anything I can do to fix the issue or should I just return the PVR for a hardware issue?
I never said the OP shouldn't update his capture software.
However if that doesn't help and the OP already has a splitter, my solution is also a low-cost fix. Connecting the TV directly to the splitter has the added benefit of allowing one to use the source device with the TV even if the HD-PVR 2's power supply is not plugged in.
Hauppauge HD PVR 2 Gaming Edition Issue, Hauppage Capture Freeze/crash
By mrlolcat1999 in forum Capturing and VCRReplies: 1Last Post: 16th Oct 2013, 18:57 -
Capture Quality with Hauppage HD PVR
By imdanwhou in forum Capturing and VCRReplies: 4Last Post: 16th Dec 2012, 20:48 -
Hauppage HD PVR
By xX-Towrd01-Xx in forum Capturing and VCRReplies: 6Last Post: 19th Mar 2012, 16:15 -
I can't capture in 720p with my Hauppage HD PVR
By Lotus Prince in forum Capturing and VCRReplies: 27Last Post: 26th Jan 2012, 00:34 -
Hauppage HD PVR or Colossus?
By yearofthespider2k3 in forum DVB / IPTVReplies: 10Last Post: 18th Apr 2011, 20:16
