  1. So I've got an mkv video. I usually use the ffms2 plugin to open videos, but it didn't work (just said "couldn't open"). I also tried DirectShowSource, but it didn't open it either.
    Somehow, virtualdub did opened it (probably because of the ffinputdriver). So I encoded it to avi (no other editing, just so it will be avi) with virtualdub and then tried to open it in avsp with AviSource, still no luck. Why won't it open this video?!
    Video info:
    General
    Unique ID                                : 199069539360921106638242983202429760462 (0x95C366105ADFC63CAB333B7DFDAE73CE)
    Complete name                            : F:\Sample\Sample.mkv
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 1.22 GiB
    Duration                                 : 23mn 43s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 7 364 Kbps
    Encoded date                             : UTC 2014-02-10 16:09:47
    Writing application                      : mkvmerge v6.5.0 ('Isn't she lovely') built on Oct 20 2013 12:50:05
    Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
    Video
    Format profile                           : High 10@L5.1
    Format settings, ReFrames                : 14 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 23mn 43s
    Nominal bit rate                         : 4 000 Kbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.080
    Writing library                          : x264 core 132 r2323+704+51 d571b1c tMod [10-bit@4:2:0 X86]
    Encoding settings                        : cabac=1 / ref=14 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.00 / psy_rd=0.60:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=500 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=8 / qpmax=32 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=4:0.80 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
    Default                                  : Yes
    Forced                                   : No
    Color range                              : Limited
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : FLAC
    Format/Info                              : Free Lossless Audio Codec
    Codec ID                                 : A_FLAC
    Duration                                 : 23mn 43s
    Bit rate mode                            : Variable
    Sampling rate                            : 48.0 KHz
    Bit depth                                : 24 bits
    Writing library                          : libFLAC 1.2.1 (UTC 2007-09-17)
    Language                                 : Japanese
    Default                                  : Yes
    Forced                                   : No
    Text
    Format                                   : PGS
    Muxing mode                              : zlib
    Codec ID                                 : S_HDMV/PGS
    Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
    Default                                  : Yes
    Forced                                   : No
    Menu
    00:00:00.000                             : en:00:00:00.000
    00:01:14.408                             : en:00:01:14.408
    00:02:45.040                             : en:00:02:45.040
    00:13:24.012                             : en:00:13:24.012
    00:21:32.208                             : en:00:21:32.208
    00:23:36.999                             : en:00:23:36.999
  2. Use a newer ffms2 version , or use l-smash
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Or use the correctly worded script.......
  4. I suspect it is the FLAC audio.
    Try demuxing the file and load the VIDEO only
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
  5. I suspect it is the FLAC audio
    So did I. However I made a test using DirectShowSource which worked without problems.
