Hi
I'm trying to convert the Mission: Impossible II PAL DVD to MP4 using VidCoder, but it always fails at the same point (1h 7m). I ripped the DVD with DVD Shrink in Re-author mode selecting only the main movie, english sound track and portuguese subtitles. Sice it is a 2001 DVD, DVD Shring doesn't seem to have any problem ripping it.
I also tried ripping with DVDFab in Movie Only mode selecting the same audio and subtitle, but the result was the same: rip was OK, but VidCoder failed.
I would appreciate if anyone could take a look at the log and maybe find something in it that shows why VidCoder is failing.
Code:## VidCoder 1.5.31.0 (x64) # Starting job 1/1 # Path: D:\Work\DVD\MISSION_IMPOSSIBLE_II # Title: 1 # Range: All # Worker ready: Service state is Opened on pipe VidCoderWorker.363435c3-ca0d-484a-8341-a7fd5f0097bc # Connecting to process 4480 on pipe VidCoderWorker.363435c3-ca0d-484a-8341-a7fd5f0097bc [20:08:55] hb_init: starting libhb thread [20:08:55] CPU: Intel(R) Pentium(R) CPU G630 @ 2.70GHz [20:08:55] - Intel microarchitecture Sandy Bridge [20:08:55] - logical processor count: 2 [20:08:55] OpenCL device #1: Advanced Micro Devices, Inc. Cedar [20:08:55] - OpenCL version: 1.1 AMD-APP (831.4) [20:08:55] - driver version: CAL 1.4.1646 (VM) [20:08:55] - device type: GPU [20:08:55] - supported: YES [20:08:55] Intel Quick Sync Video support: no [20:08:55] hb_scan: path=D:\Work\DVD\MISSION_IMPOSSIBLE_II, title_index=1 libbluray/bdnav/index_parse.c:162: indx_parse(): error opening D:\Work\DVD\MISSION_IMPOSSIBLE_II/BDMV/index.bdmv libbluray/bdnav/index_parse.c:162: indx_parse(): error opening D:\Work\DVD\MISSION_IMPOSSIBLE_II/BDMV/BACKUP/index.bdmv libbluray/bluray.c:2182: nav_get_title_list(D:\Work\DVD\MISSION_IMPOSSIBLE_II) failed [20:08:55] bd: not a bd - trying as a stream/file instead libdvdnav: Using dvdnav version 5.0.1 libdvdread: Encrypted DVD support unavailable. libdvdread: Can't open D:\Work\DVD\MISSION_IMPOSSIBLE_II for reading libdvdread: Device D:\Work\DVD\MISSION_IMPOSSIBLE_II inaccessible, CSS authentication not available. libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 1 2 3 4 5 6 7 8 libdvdread: Encrypted DVD support unavailable. libdvdread: Can't open D:\Work\DVD\MISSION_IMPOSSIBLE_II for reading libdvdread: Device D:\Work\DVD\MISSION_IMPOSSIBLE_II inaccessible, CSS authentication not available. [20:08:55] scan: DVD has 1 title(s) [20:08:55] scan: scanning title 1 [20:08:55] scan: opening IFO for VTS 1 [20:08:55] scan: duration is 01:58:29 (7109000 ms) [20:08:55] pgc_id: 1, pgn: 1: pgc: 00000000008292C0 [20:08:55] scan: vts=1, ttn=1, cells=0->17, blocks=0->2290761, 2290762 blocks [20:08:55] scan: checking audio 1 [20:08:55] scan: id=0x80bd, lang=English (AC3), 3cc=eng ext=1 [20:08:55] scan: checking subtitle 1 [20:08:55] scan: id=0x29bd, lang=Portugues, 3cc=por ext=1 [20:08:55] scan: title 1 has 17 chapters [20:08:55] scan: chap 1 c=0->0, b=0->103917 (103918), 340480 ms [20:08:55] scan: chap 2 c=1->1, b=103918->196654 (92737), 270880 ms [20:08:55] scan: chap 3 c=2->2, b=196655->324325 (127671), 425760 ms [20:08:55] scan: chap 4 c=3->3, b=324326->435802 (111477), 329840 ms [20:08:55] scan: chap 5 c=4->4, b=435803->608493 (172691), 633480 ms [20:08:55] scan: chap 6 c=5->5, b=608494->811468 (202975), 625480 ms [20:08:55] scan: chap 7 c=6->6, b=811469->1010200 (198732), 602600 ms [20:08:55] scan: chap 8 c=7->7, b=1010201->1164739 (154539), 517200 ms [20:08:55] scan: chap 9 c=8->9, b=1164740->1282849 (118110), 375240 ms [20:08:55] scan: chap 10 c=10->10, b=1282850->1414031 (131182), 389160 ms [20:08:55] scan: chap 11 c=11->11, b=1414032->1554686 (140655), 436440 ms [20:08:55] scan: chap 12 c=12->12, b=1554687->1732487 (177801), 556520 ms [20:08:55] scan: chap 13 c=13->13, b=1732488->1815358 (82871), 265360 ms [20:08:55] scan: chap 14 c=14->14, b=1815359->2023532 (208174), 534080 ms [20:08:55] scan: chap 15 c=15->15, b=2023533->2111585 (88053), 254600 ms [20:08:55] scan: chap 16 c=16->16, b=2111586->2213349 (101764), 287160 ms [20:08:55] scan: chap 17 c=17->17, b=2213350->2290761 (77412), 264720 ms [20:08:55] scan: aspect = 1.77778 [20:08:55] scan: decoding previews for title 1 libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 1 2 3 4 5 6 7 8 [20:08:55] scan: title angle(s) 1 [ac3 @ 000000002194b720] frame sync error [ac3 @ 000000000085b460] frame sync error [20:08:55] scan: audio 0x80bd: ac3, rate=48000Hz, bitrate=448000 English (AC3) (5.1 ch) [20:08:55] Broken timestamps detected. Reordering. [20:08:55] scan: 10 previews, 720x576, 25.000 fps, autocrop = 76/78/10/8, aspect 16:9, PAR 64:45 [20:08:55] libhb: scan thread found 1 valid title(s) [20:08:56] 1 job(s) to process [20:08:56] starting job [20:08:56] Auto Passthru: allowed codecs are AAC, AC3, DTS, DTS-HD, MP3 [20:08:56] Auto Passthru: no valid fallback specified [20:08:56] Auto Passthru: using AC3 Passthru for track 0 [20:08:56] sync: expecting 177725 video frames [20:08:56] job configuration: [20:08:56] * source [20:08:56] + D:\Work\DVD\MISSION_IMPOSSIBLE_II [20:08:56] + title 1, chapter(s) 1 to 17 [20:08:56] * destination [20:08:56] + D:\Work\DVDRip\Mission Impossible II.mp4 [20:08:56] + container: MPEG-4 (libavformat) [20:08:56] + chapter markers [20:08:56] * video track [20:08:56] + decoder: mpeg2video [20:08:56] + bitrate 9800 kbps [20:08:56] + filters [20:08:56] + Framerate Shaper (0:27000000:1080000) [20:08:56] + frame rate: same as source (around 25.000 fps) [20:08:56] + Crop and Scale (702:422:76:78:10:8) [20:08:56] + source: 720 * 576, crop (76/78/10/8): 702 * 422, scale: 702 * 422 [20:08:56] + loose anamorphic [20:08:56] + storage dimensions: 702 * 422, mod 2 [20:08:56] + pixel aspect ratio: 64 / 45 [20:08:56] + display dimensions: 998 * 422 [20:08:56] + encoder: H.264 (libx264) [20:08:56] + preset: veryfast [20:08:56] + profile: main [20:08:56] + level: 4.0 [20:08:56] + quality: 20.00 (RF) [20:08:56] * subtitle track 1, Portugues (track 1, id 0x29bd) Picture [VOBSUB] -> Passthrough, Default [20:08:56] * audio track 1 [20:08:56] + decoder: English (AC3) (5.1 ch) (track 1, id 0x80bd) [20:08:56] + bitrate: 448 kbps, samplerate: 48000 Hz [20:08:56] + AC3 Passthru libdvdnav: Using dvdnav version 5.0.1 libdvdread: Encrypted DVD support unavailable. libdvdread: Can't open D:\Work\DVD\MISSION_IMPOSSIBLE_II for reading libdvdread: Device D:\Work\DVD\MISSION_IMPOSSIBLE_II inaccessible, CSS authentication not available. libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 1 2 3 4 5 6 7 8 libdvdread: Encrypted DVD support unavailable. libdvdread: Can't open D:\Work\DVD\MISSION_IMPOSSIBLE_II for reading libdvdread: Device D:\Work\DVD\MISSION_IMPOSSIBLE_II inaccessible, CSS authentication not available. libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 1 2 3 4 5 6 7 8 [20:08:56] reader: first SCR 146 id 0xe0 DTS 14202 [20:08:56] mpeg2video: "Chapter 1" (1) at frame 0 time 3600 [20:08:56] encx264: encoding at constant RF 20.000000 [20:08:56] encx264: unparsed options: level=4.0:ref=1:8x8dct=0:weightp=1:subme=2:mixed-refs=0:trellis=0:vbv-bufsize=25000:vbv-maxrate=20000:rc-lookahead=10 x264 [info]: using SAR=64/45 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 x264 [info]: profile Main, level 4.0 [20:08:56] sync: first pts is 3600 [20:09:59] mpeg2video: "Chapter 2" (2) at frame 8512 time 30646800 [20:10:53] sync: audio 0x80bd time went backwards 15 ms, dropped 1 frames (start 55006571, next 55008000) [20:10:53] mpeg2video: "Chapter 3" (3) at frame 15282 time 55018800 [20:12:03] mpeg2video: "Chapter 4" (4) at frame 25928 time 93341520 [20:13:06] mpeg2video: "Chapter 5" (5) at frame 34172 time 123019920 [20:14:43] mpeg2video: "Chapter 6" (6) at frame 50011 time 180040320 [20:16:39] mpeg2video: "Chapter 7" (7) at frame 65646 time 236326320 [20:18:32] mpeg2video: "Chapter 8" (8) at frame 80711 time 290560320 [20:19:56] mpeg2video: "Chapter 9" (9) at frame 93643 time 337115520 avformatMux: track 2, av_interleaved_write_frame failed with error 'Error number -22 occurred' [20:20:55] reader: done. 6 scr changes [20:20:55] work: average encoding speed for job is 142.311935 fps [20:20:55] sync: got 102393 frames, 177725 expected [20:20:55] render: lost time: 0 (0 frames) [20:20:55] render: gained time: 0 (0 frames) (0 not accounted for) [20:20:55] mpeg2video-decoder done: 102397 frames, 0 decoder errors, 0 drops x264 [info]: frame I:1661 Avg QP:18.00 size: 25760 x264 [info]: frame P:49652 Avg QP:20.97 size: 7324 x264 [info]: frame B:51036 Avg QP:22.26 size: 1838 x264 [info]: consecutive B-frames: 18.6% 39.2% 16.6% 25.6% x264 [info]: mb I I16..4: 40.5% 0.0% 59.5% x264 [info]: mb P I16..4: 16.2% 0.0% 2.6% P16..4: 34.3% 15.9% 8.5% 0.0% 0.0% skip:22.5% x264 [info]: mb B I16..4: 1.6% 0.0% 0.1% B16..8: 17.4% 5.5% 0.7% direct:10.8% skip:63.9% L0:30.0% L1:49.7% BI:20.4% x264 [info]: coded y,uvDC,uvAC intra: 45.6% 49.5% 14.4% inter: 16.5% 15.4% 0.6% x264 [info]: i16 v,h,dc,p: 43% 22% 24% 11% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 17% 20% 5% 6% 6% 5% 6% 5% x264 [info]: i8c dc,h,v,p: 54% 19% 22% 5% x264 [info]: Weighted P-Frames: Y:3.9% UV:1.3% x264 [info]: kb/s:977.58 [20:20:55] ac3-decoder done: 0 frames, 0 decoder errors, 0 drops [20:20:55] mux: track 0, 100891 frames, 493102126 bytes, 977.49 kbps, fifo 4096 [20:20:55] mux: track 1, 126113 frames, 225994496 bytes, 448.00 kbps, fifo 4096 [20:20:55] mux: track 2, 600 frames, 1556336 bytes, 3.09 kbps, fifo 32 [20:20:55] libhb: work result = 4 # Encode failed. # Job completed (Elapsed Time: 12m 02s)
"The greatest trick the Devil ever pulled was convincing the world he didn't exist."
Can you play the ripped dvd okey? Check around 1h 7m.
I ran FixVTS on the folder that was ripped with DVD Shrink, but it didn't help. Then I used DVD Decrypter in File mode to rip the entire DVD, but VidCoder failed again, before and after running FixVTS.
I don't get it. Usualy, DVDs from that period are pretty easy to backup."The greatest trick the Devil ever pulled was convincing the world he didn't exist." -
How to easily burn in/hardcode srt subtitles to mp4/mkv with VidCoder
By Baldrick in forum User guidesReplies: 65Last Post: 25th Jun 2024, 02:11 -
How do I convert MKV to MP4 in batch with burned-in subs? (Vidcoder)
By fighuass in forum Video ConversionReplies: 12Last Post: 29th Aug 2021, 12:02 -
Please help hardcoding .srt subs to MP4 using Vidcoder or else...
By novice121 in forum SubtitleReplies: 7Last Post: 30th Nov 2015, 14:52 -
Vidcoder no longer creates playable mp4's from Bluray? (VLC or anything)?
By David Ross in forum Blu-ray RippingReplies: 17Last Post: 6th May 2012, 04:27 -
mission impossible ghost protocol - Back up suggestion? Failing..
By Hal05154 in forum Newbie / General discussionsReplies: 7Last Post: 20th Apr 2012, 21:21
