Hi
I have an old laptop running WinXP. It has wifi, ethernet, usb and a firewire port. It also has a PCMCIA slot. I have a Panasonic HDC-SD60 camera with HDMI, usb and AV (component & composite) ports.
How do I capture video (say using VLC)?
I tried the usb-to-usb option but that is playback only. There don't appear to be any form of firewire-to-HDMI adapters or HDMI-over-IP (wifi or ethernet) adapters. I'm stuck!
Andy
Results 1 to 18 of 18
Grass Valley ADVC110 ... about $179.00 would be best considering aging xp system ... 720 capture max
Pcmcia ... anything above 480 via this connection is limited by data bandwidth, then frames lower.
And welcome to the forum -
I can't see why you would want to try and 'capture' video from this camera, (as in 're-record' it onto your computer)...I'm guessing you probably mean you want to 'transfer' the video to your computer ?
Simply remove the SD card that contains your footage, and fit it into a card reader (something like THIS for example).
Then you can copy the .MTS files directly from the card - (those are the actual video files)
You can find the .MTS files in the card folder structure by following this sequence: "PRIVATE - AVCHD - BDMV - STREAM'.
Or - you can use HD Writer software to copy the complete file structure from the card, and then use HD Writer to view your clips and carry out simple edits. That lets you keep all the metadata in the files as well as the video itself.
Either way, you won't lose any quality by doing that.. which you will do, if you try and 'capture' your video by playing it in camera, and recording it again onto the computer.
If you don't have a copy of HD Writer, you can find one HERE (You will need version AE 2.0 )Last edited by pippas; 19th Aug 2015 at 04:34. Reason: extra info
Ahhh.. so a card reader is not really suitable then !
With regard to the Grass Valley converters, you might like to check out the cheaper ADVC55, which has only just been discontinued within the past couple of months (Grass Valley are 'rationalising' their DV converter range)
It's the same quality as the ADVC110, but doesn't include the (little used) digital to analogue output option
There's a new one for sale HERE: for example. About £80 cheaper than an ADVC110 from Amazon
Don't forget that the ADVC converters produce 720x576 DV images, so you'll need to ensure you can display the original aspect ratio of the 16x9 footage from your Panasonic camera, and that your chosen player can also 'stream' DV.....
Or, if the budget is a bit tight, maybe take a look at one of THESE instead?. Beware of fakes though... probably best to buy direct I'm thinking... -
Isn't that a high definition camcorder? Why would you want to capture standard definition with an ADVC110? Get a USB HD HDMI capture device suitable for use with VLC. Verify the camcorder puts out a live HDMI signal.
I don't care about SD or HD . . . I am struggling to find anything that works.
I can't see how what you suggest might work? I googled "USB HD HDMI capture device" but it was either usb-in / HDMI-out or HDMI-to-component/composite. I need HDMI/component/composite-to-firewire/usb don't I? -
Try something like the blackmagic intensity shuttle. Though if the ADVC is beyond your budget this probably is too.
On a laptop the typical inputs that can be used to capture video are USB and firewire. The latter is very rare these days. Oh, and the Thunderbolt port on a Mac.
Thanks very much to everyone.
I got a reply from the Ezcap people:
"Our 116 EzCAPTURE product will do this for you. You connect the unit to your camcorders av composite cable.
You can use the capture software included on the install disc or VLC.
http://www.ezcap.tv/usb-video-capture/ezcap116-capture-card"
Hopefully this will work!
Help me set-up my desktop to an HDTV (with different ports)
By sgt244 in forum ComputerReplies: 10Last Post: 12th Aug 2013, 22:38 -
Can you see (6) SATA ports on this mobo?
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 3rd Feb 2013, 12:10 -
USB-3 Secondary Ports Fail.
By sambat in forum ComputerReplies: 0Last Post: 26th Nov 2012, 14:54 -
How to add more router ports?
By siratfus in forum ComputerReplies: 23Last Post: 1st Oct 2012, 10:24 -
No usb ports working is motherboar dead
By Humbug in forum ComputerReplies: 31Last Post: 24th Dec 2010, 17:27
