Hi all,
i have a bunch of completely same format avi files (RIFF). I've analysed one of them with media info and putted the result at the end of this post.
All videos are taken by 'Garmin dash cam 20' which geographically tags the video at the same time that video is encoded and make it possible to see lat/lon of position of camera at each second of video. ok?
There are many dash cam video players that while they playing the video, also they show the position of camera on a map beside the playing video (see this screenshot for example). All of them are able to play video but non of them (expect Garmin dash cam player) are not able to detect geotags! These are dash cam players i've checked my video:
- Action Cam
- Cobra Dash Cam Player
- DATAKAM
- DODPlayer
- DashCam viewer
As I've said only Garmin dash cam player was able to show geo position while playing the video. This is all files that GDC (Garmin Dash Cam) player have installed and uses them to extract geo info from videos (maybe be useful to find out how it works behind the scene)
What i need to know is to find a way to pragmatically extract only the Latitude and Longitude info at each second of video. A good alternative would be a console executable file that gets video file address from execution parameters and process video file and writes the result into a text file etc.
This is a very small commercial app and actually i'm not a video nerd, i do not know much about video so i can pay up to $150 for such an application (I'm also a freelancer!!!).
This is also example video that is taken with camera, final application should work with this file (and file only like this, with same format)
https://goo.gl/3g77EO
This video plays fine in GDC player and shows lat/lon in map while playing video.
A very good application was "AVCHD2SRT" (available from here also here) this was exactly what i need but unfortunately it do not work with my videos.
Media info output on my file:
Code:General Complete name : *!\VDO.avi Format : AVI Format/Info : Audio Video Interleave File size : 6.68 MiB Duration : 6s 2ms Overall bit rate : 9 343 Kbps Video ID : 0 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : H264 Duration : 6s 0ms Bit rate : 9 124 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.147 Stream size : 6.53 MiB (98%) Audio ID : 1 Format : ADPCM Codec ID : 2 Codec ID/Hint : Microsoft Duration : 6s 2ms Bit rate mode : Constant Bit rate : 176.4 Kbps Channel(s) : 1 channel Sampling rate : 44.1 KHz Bit depth : 4 bits Stream size : 130 KiB (2%) Interleave, duration : 46 ms (1.38 video frame)
	It looks like the GPS data is in the GR02 chunk. See post #29 in this thread:
 https://translate.google.com/translate?hl=en&sl=ja&u=http://kohada.2ch.net/test/read.c...6/&prev=search
 From VirtualDub's hex editor and RIFF chunk viewer:
	Thanks for information, that was very helpfull. I did extracted data i was wanted...
 Thank you
 for further info:
 http://gis.stackexchange.com/questions/157114/how-to-extract-gps-information-from-garm...20-video-filesLast edited by epsi1on; 31st Aug 2015 at 03:09.
  help with geo blocked youtube videoBy blade2005 in forum Video Streaming DownloadingReplies: 8Last Post: 8th Nov 2015, 05:47
  H264 video cutter with smart re-encoding (alternative to VideoRedo H264)By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2014, 09:42
  Need Better Program than AbcAVi to edit video file tagsBy Whitezombie455 in forum Newbie / General discussionsReplies: 5Last Post: 6th Feb 2013, 03:17
  [MKV] Need help extracting H264 video from an MKV into an editable mediumBy SinanDira in forum Video ConversionReplies: 2Last Post: 12th Sep 2011, 12:44
  How to add tags to a video file in windows 7?By Rudyard in forum ComputerReplies: 0Last Post: 8th Jan 2011, 19:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
