Results 1 to 19 of 19
    Aug 2015
    I edited and burned my first Blu-Ray (as opposed to DVDs) using Movie Edit Pro 2015. No error messages or other issues with the burning process and in fact MEP said it was burned successfully. My blu-ray player won't play it but it's also not giving any error messages. When the tray with the disc slides in, the menu simply says BDMV (as opposed to DVD+R which works). It won't play; it doesn't do anything really. The firmware version is M.24.R.0214 on the blu-ray player.
    Frustrated mostly because I'm sure there's something real obvious I'm missing.
    canada
    Try burning with imgburn and see if any error message pop up with imgburn,if it doesn't show any error or recommendations to change settings then burn away,i have the same blu-ray player as you and it has no issues playing burned blu-ray discs as long as they were authored properly and burned the right way.
    Aug 2015
    How do I do that? I've never used imgburn. I have it on my computer now but what about the burning part? Do I burn the 3 folders I have now (AACS, BDMV, and Certificate)? Or does Magix have a completed file that I forgot where it's saved on my PC?
  4. Go to the imgburn website and look at their guides. Be sure to check out their forum for more detailed guides.
    Extraordinary claims require extraordinary evidence -Carl Sagan
    Feb 2006
    what brand of blank discs do you use??
  6. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    I'm assuming you have your Blu-ray project saved as folders. Open imgburn, and select Write Files/Folders to Disc, choose the parent folder, and imgburn should recognize it as a Blu-ray. Allow it to change the file system if it prompts you, and proceed with the burn. Easy Peasy.
    -The Mang
  7. satan's little helper teamsatan's Avatar
    Feb 2011
    I also have the same Blu-Ray player, burning with ImgBurn and have never had any problems with the discs. have probably tried about 8 different brands, and all have worked perfectly.
    Aug 2015
    I tried it. Same result: nothing. On the Blu-Ray player's menu it says BD-R BDMV. No error message. It just doesn't play. Screen goes black for a second, as if it was going to play but just goes back to the main menu. At least if it would give me an error message I would have something to go on. But I don't even have that. Even my old DVD's that I burned before I had a blu-ray player work. On the main menu it says DVD+R but it plays. And when I burned this disc using Imgburn, it said it worked just fine.
    Aug 2015
    The instructions with the Blu-Ray player state "The BD-Rs recorded on a PC cannot be played if postscripts are recordable." What does that mean? Could I have done that without realizing it? If it's something simple that I could have done wrong, then I probably did. I know just enough to get by because between school and work, my mind is pretty well spent some days.
  10. Member wulf109's Avatar
    Jul 2002
    What's the video FPS of your video?
    Aug 2015
    29.97 fps
    Feb 2006
    did you try asking your question on MAGIX community forum?? - http://www.magix.info/us/
    Aug 2015
    I'd be happy if I could get an answer to what does "The BD-Rs recorded on a PC cannot be played if postscripts are recordable" mean? I have no idea what postscripts are let alone if they're "recordable." I've tried to Google that all it comes up with is other people on other websites asking the same question but no answers.
    Feb 2006
    the only thing that i found is the disc must be finalized - https://forum.videohelp.com/threads/337862-sony-bdv-e370-will-not-play-bd25
    read post #2
  15. I'm a Super Moderator johns0's Avatar
    canada
    I also read that it also be a problem with the discs you are using,have you tried verbatim?
  16. Member wulf109's Avatar
    Jul 2002
    Backup a Blueray disk with BDRB,burn with Imgburn and see if it plays. If that works it isn't the Sony player. The problem is in how you authored with the program you used. The postscrip note is the player telling you the disk is not correctly formatted to play.
    Aug 2015
    I tried authoring all over again and encoding to Directory so I can burn it using Img Burn (or something like that). Would not even start. This is the error log and I haven't left anything out; it is that short:
    10/4/2015 2:14:28 AM.803: Open Project: Project_1 -- bd project 2015-10-04
    10/4/2015 2:14:28 AM.804: VideoMode: NTSC Temp Dir: C:\Users\DougG\Videos\
    10/4/2015 2:14:28 AM.804: dll version 5.0.10.0
    10/4/2015 2:14:28 AM.810: Step 1 of 9, Encoding movie 1 ...
    10/4/2015 2:14:29 AM.040: Step 1 done
    10/4/2015 2:14:29 AM.044: ERROR: PrepareDVDVideoFiles() failed with errNo 5 - encoding failed
    10/4/2015 2:14:29 AM.045: !!! DBK error in BurnProject: 10 - movie encoding failed !!!
  18. Member
    Dec 2015
    california
    here is my issue,i will be shooting a wedding in 3D using 2 fuji 3d video cameras.although it produces great 3D video i cannot seem to figure out how to burn it so that it plays like a commercial blu ray.i always need to switch the 3D tv to half side by side.why doesn't the Panasonic 3D player just play it as a sequential like the commercial blu ray.is there a code to trigger this I'm just not adding? i cannot seem to get an answer for this any help would be appreciated.i want to make the bluray just load in and play as many users aren't to savoy with changing the TV settings.
  19. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    whitefalcon74 - you really should start your own thread. your question has nothing to do with this post.
    but in answer to your question. your side by side 3d isn't anything like factory 3d blurays as they are recorded as mvc.
