Someone can help please, this following command didn't work:
ffmpeg -i "blessing 14_8_2015_v1.flv" -vcodec mpeg4 -b:a 200000 -s 853x480 -vtag DX50 -ar 44100 -ab 128 -ac 2 -acodec mp3 -vol 100 "Output.divx"
result :
[NULL @ 0000000002929980] Unable to find a suitable output format for 'Output.divx'
Output.divx: Invalid argument
- My sister Ann's brother
"Optimal" or not, they do work.
Decent encoders know how to deal with mod4 and mod2 frame dimensions.
Decent decoders know how to discard the junk used for filling in the 8x8 or 16x16 blocks.
AFAIK, only the MPEG-1 and MPEG-2 encoders are forever bound to the 8x8-block restriction. -
how to convert flv to divx in order to play in a dvdplayer
If your hardware is 'ancient', then you can't use anything above 720x576, IIRC.
I stopped using standalone DVD-players years ago, this is the reason why I don't care about
mod16, maximum bitrates, etc Etc ETC, anymore.Last edited by El Heggunte; 16th Aug 2015 at 09:34. Reason: clarity
Yes, it does. 720x576@25fps are maximum width and height for PAL standard and 720x480@29,97fps are maximum width and height for NTSC standard. If your original intent was to encode in 854x480 resolution you should use 720x400 for mod 16 and to keep aspect ratio.
Uploading to Youtube causes audio to play in the wrong order
By Ifcpeo in forum Newbie / General discussionsReplies: 10Last Post: 22nd May 2014, 00:13 -
Trying to convert multiple mkvs to avi to play on divx dvd player?
By ericc54321 in forum Video ConversionReplies: 6Last Post: 23rd Mar 2014, 23:57 -
Convert iPhone movie in order to upload into Premiere CS6
By p_uriel in forum Video ConversionReplies: 4Last Post: 14th Mar 2014, 16:19 -
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 12:39
