[SOLVED]
Do madvr has x64 version ?
https://www.videohelp.com/software/madVR
THANKS![]()
Yes, since v0.87.20. You have it in one zip file.
http://forum.doom9.org/showthread.php?p=1717279#post1717279 -
All new versions has 64bit included. Extract all files and run the install.bat.
Tell me you are joking, right?
. 64 bits were implemented in 0.87.20. So all versions after that have it. General understanding is that when some new feature is added to any application, it's in all new versions of it after that. You've spent more time asking questions than when downloading zip file, checking up its content, installing it and checking if it's recognised by a 64bit video player (MPC-HC/BE for example).
PotPlayer - How to use MadVR?
By jackuars in forum Software PlayingReplies: 49Last Post: 3rd Dec 2021, 17:20 -
madVR Problem
By haithomy in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2014, 22:47 -
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 20Last Post: 19th May 2014, 12:55 -
What version of CCE to use with DVD-RB and Win7 U 64bit
By Alloneword in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2012, 18:29 -
Lame MP3 on Virtualdub 64bit (win7 64bit)
By EdoScario90 in forum AudioReplies: 5Last Post: 2nd Sep 2012, 10:30
