specs: dell laptop, windows 7 home premium, 64bit
I've been searching but not finding anything that works.
So far, I've downloaded:
* 1200ub_9xzip (but the install failes, not a valid 32/64bit driver for my windows home premium)
* vuex6495.exe (but after the installation and I run the app, the software says it can't locate the driver for this scanner)
Thanks in advanced.
Results 1 to 11 of 11
not gonna happen. the last driver released for the Mustek 1200 UB Plus was for Windows 98 / ME / 2000 / XP.
you are correct. I just found this one (tried both listed in the tree -- xp version) and it would not install.
ftp://ftp2.mustek.com.tw/pub/new/driver/0_Old%20Products/
I guess I'll have to connect it to my desktop xp then. Thanks. -
I need a flat bed scanner for sensitive papers. ie, my birth certificate will tare if i run it through any of my sheet feed scanners.
I guess I will head over to staples tomorrow and pick up a newer model. I don't think I will need a real high quality, though it wouldn't hurt -- if the price is right. -
i use an epson flatbed v30 with an led lightsource. cheap fast and works.
Well, I tried those windows xp drivers on my desktop xp but the drivers would not work either.
I keep getting the "system DLLs corrupt or missing" error message. Anyway.
While cleaning around in my apt last week, I was sure I had the original Mustek 1200 UB driver cd and stashed it in a box somewhere. And I do remember the scanner being pretty slow at scanning a page, about 40 seconds or so. But I think I will go with a newer generation (faster) flatbed scanner, though it would be nice if I can get this old one up and working again. -
The all in one printers do a decent job of scanning. Most cost about the same or less then a dedicated scanner.
Extraordinary claims require extraordinary evidence -Carl Sagan -
maybe check this out.....
http://www.hamrick.com/vuescan/mustek_1200_ub_plus.html# -
update.. After careful research, I ended up getting the Epson Perfection V39 flatbed scanner at Staples.
http://www.amazon.com/Epson-Perfection-V39-Document-Scan-To-Cloud/dp/B00SSXQ7Q2
I could have gotten it $20 cheaper online but I didn't want to wait this time. Anyway.
I've been testing it out. Its not all that bad for a casual scanner. Scanning speed is about 12 seconds per page though in a review I read, it stated 5 PPM. So, that's about right I think. And there are other factors to the scanning process that would bring that number lower. But for basic manual scanning, 5 PPM is ok. Although I don't know why it says 4800 dpi when the max I could get in some of the different scan settings I tried were 1200 dpi. Anyway. So far so good.
sample images
https://forum.videohelp.com/attachment.php?attachmentid=33189&stc=1&thumb=1&d=1439782733
* epson.perfection.v39.img08162015_color0600dpi.0001
https://forum.videohelp.com/attachment.php?attachmentid=33190&stc=1&thumb=1&d=1439782733
* epson.perfection.v39.img08162015_color1200dpi.0002
Some Windows 8.1 updates tripping over driver problems
By enim in forum Latest Video NewsReplies: 4Last Post: 2nd Mar 2014, 08:47 -
Any solution for Handycam / Windows 7 driver problem?
By tedmarx38 in forum Capturing and VCRReplies: 4Last Post: 11th Nov 2012, 11:39 -
Scanning super-8, frame-by-fram, using a regular flatbed scanner
By MrTemplar in forum Capturing and VCRReplies: 13Last Post: 2nd Oct 2012, 13:27 -
EasyCap Video Adapter Driver for Windows 7 64-bit
By Naymark.com in forum Capturing and VCRReplies: 4Last Post: 26th Mar 2012, 01:08 -
Windows 7 driver for Syntek STK1160
By helionfilm in forum DVB / IPTVReplies: 1Last Post: 27th Oct 2011, 18:49
