  1. Hello, i would like to convert the DVD.iso for a file.mkv and leave it the way it is, with subtitles in right color.
    I do not know what it is about these errors because the CSS has been decrypted, and is showing two VOB tracks, despite containing 6.
    I'm using a VPS with OpenVZ Debia 7 x64 and can not mount a virtual disk.
    If i extract the files.VOB and convert them to .mkv, subtitles are in black and there are some lacks in the video/audio (and in the conversion log). In addition to the disruption of menus.
    i run the default HB command, it dont convert and returns some errors.
    Is there a way to compress the iso and preserve all DVD structure? Or if it not possible, set a color to subtitles?
    # HandBrakeCLI -i dvd.iso -o test.mkv
    [20:58:04]  - logical processor count: 4
    [20:58:04] OpenCL: library not available
    [20:58:04] hb_scan: path=dvd.iso, title_index=1
    libbluray/bdnav/index_parse.c:162: indx_parse(): error opening dvd.iso/BDMV/index.bdmv
    libbluray/bdnav/index_parse.c:162: indx_parse(): error opening dvd.iso/BDMV/BACKUP/index.bdmv
    libbluray/bluray.c:2182: nav_get_title_list(dvd.iso) failed
    [20:58:04] bd: not a bd - trying as a stream/file instead
    libdvdnav: Using dvdnav version 5.0.1
    libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 1 2 3 4 5 6 7 8
    [20:58:04] scan: DVD has 32 title(s)
    [20:58:04] scan: scanning title 1
    [20:58:04] scan: opening IFO for VTS 1
    [20:58:04] scan: duration is 00:02:01 (121233 ms)
    [20:58:04] pgc_id: 1, pgn: 1: pgc: 0x7ffe8000ee90
    [20:58:04] scan: vts=1, ttn=1, cells=0->1, blocks=2206674->2238144, 31471 blocks
    [20:58:04] scan: checking audio 1
    [20:58:04] scan: id=0x80bd, lang=Espanol (AC3), 3cc=spa ext=0
    [20:58:04] scan: checking subtitle 1
    [20:58:04] scan: id=0x20bd, lang=Espanol, 3cc=spa ext=0
    [20:58:04] scan: checking subtitle 2
    [20:58:04] scan: id=0x21bd, lang=Portugues, 3cc=por ext=0
    [20:58:04] scan: title 1 has 2 chapters
    [20:58:04] scan: chap 1 c=0->0, b=2206674->2209431 (2758), 14667 ms
    [20:58:04] scan: chap 2 c=1->1, b=2209432->2238144 (28713), 106567 ms
    [20:58:04] scan: aspect = 1.77778
    [20:58:04] scan: decoding previews for title 1
    [20:58:04] scan: title angle(s) 1
    libdvdread: Attempting to retrieve all CSS keys
    libdvdread: This can take a _long_ time, please be patient
    libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00000164
    libdvdread: Elapsed time 0
    libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x0000447e
    libdvdread: Found 1 VTS's
    [ac3 @ 0x7ffe800a1080] frame sync error
    [20:58:04] scan: audio 0x80bd: ac3, rate=48000Hz, bitrate=192000 Espanol (AC3) (2.0 ch)
    [20:58:04] hb_demux_ps: not a PS packet (00000000)
    [20:58:04] scan: 10 previews, 720x480, 29.970 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 32:27
    [20:58:04] libhb: scan thread found 1 valid title(s)
    + title 1:
      + vts 1, ttn 1, cells 0->1 (31471 blocks)
      + duration: 00:02:01
      + size: 720x480, pixel aspect: 32/27, display aspect: 1.78, 29.970 fps
      + autocrop: 0/0/0/0
      + support opencl: no
      + support hwd: not built-in
      + chapters:
        + 1: cells 0->0, 2758 blocks, duration 00:00:15
        + 2: cells 1->1, 28713 blocks, duration 00:01:47
      + audio tracks:
        + 1, Espanol (AC3) (2.0 ch) (iso639-2: spa), 48000Hz, 192000bps
      + subtitle tracks:
        + 1, Espanol (iso639-2: spa) (Bitmap)(VOBSUB)
        + 2, Portugues (iso639-2: por) (Bitmap)(VOBSUB)
    [20:58:04] 1 job(s) to process
    [20:58:04] starting job
    [20:58:04] work: mixdown not specified, track 1 setting mixdown Stereo
    [20:58:04] work: compression level not specified, track 1 setting compression level 2.00
    [20:58:04] work: bitrate not specified, track 1 setting bitrate 160 Kbps
    [20:58:04] sync: expecting 3633 video frames
    [20:58:04] job configuration:
    [20:58:04]  * source
    [20:58:04]    + dvd.iso
    [20:58:04]    + title 1, chapter(s) 1 to 2
    [20:58:04]  * destination
    [20:58:04]    + test.mkv
    [20:58:04]    + container: Matroska (libavformat)
    [20:58:04]  * video track
    [20:58:04]    + decoder: mpeg2video
    [20:58:04]      + bitrate 8500 kbps
    [20:58:04]    + filters
    [20:58:04]      + Framerate Shaper (0:27000000:900900)
    [20:58:04]        + frame rate: same as source (around 29.970 fps)
    [20:58:04]      + Crop and Scale (720:406:0:0:0:0)
    [20:58:04]        + source: 720 * 480, crop (0/0/0/0): 720 * 480, scale: 720 * 406
    [20:58:04]    + dimensions: 720 * 406, mod 0
    [20:58:04]    + encoder: MPEG-4 (libavcodec)
    [20:58:04]      + bitrate: 1000 kbps, pass: 0
    [20:58:04]  * audio track 1
    [20:58:04]    + decoder: Espanol (AC3) (2.0 ch) (track 1, id 0x80bd)
    [20:58:04]      + bitrate: 192 kbps, samplerate: 48000 Hz
    [20:58:04]    + mixdown: Stereo
    [20:58:04]    + encoder: MP3 (libmp3lame)
    [20:58:04]      + bitrate: 160 kbps, samplerate: 48000 Hz
    [20:58:04]      + compression level: 2.00
    [20:58:04] encavcodecInit: MPEG-4 ASP encoder
    [20:58:04] reader: first SCR 146 id 0xe0 DTS 22254
    [20:58:04] enclame: opening libmp3lame
    [20:58:04] mpeg2video: "Chapter 1" (1) at frame 0 time 3003
    [20:58:04] sync: first pts is 3003
    [20:58:04] sync: adding 96 ms of silence to audio 0x80bd  start 31680, next 23040
    libdvdnav: demux error! 00 00 00 (should be 0x000001)
    ERROR: dvdnav: Read Error, Expected NAV packet but none found.
    [20:58:04] reader: done. 1 scr changes
    [20:58:04] sync: video time didn't advance - dropped 1 frames (delta 0 ms, current 186186, next 189189, dur 3003)
    [ac3 @ 0x7ffe78138560] exponent out-of-range
    [ac3 @ 0x7ffe78138560] error decoding the audio block
    [ac3 @ 0x7ffe78138560] frame sync error
    [20:58:04] sync: adding 96 ms of silence to audio 0x80bd  start 190080, next 181440
    [20:58:04] work: average encoding speed for job is 0.000000 fps
    Encoding: task 1 of 1, 1.87 %[20:58:05] sync: got 69 frames, 3633 expected
    [20:58:05] render: lost time: 0 (0 frames)
    [20:58:05] render: gained time: 0 (0 frames) (0 not accounted for)
    [20:58:05] mpeg2video-decoder done: 70 frames, 0 decoder errors, 0 drops
    [20:58:05] ac3-decoder done: 0 frames, 0 decoder errors, 0 drops
    [20:58:05] mux: track 0, 69 frames, 106661 bytes, 365.33 kbps, fifo 128
    [20:58:05] mux: track 1, 89 frames, 41472 bytes, 142.05 kbps, fifo 128
    [20:58:05] libhb: work result = 0
    Encode done!
    HandBrake has exited.
  2. Banned
    Feb 2013
    I don't believe mkv supports menus.
    To retain menus and compress you have to do DVD to DVD
  3. Originally Posted by gonca View Post
    Yes, my mistake, but i would like to convert all DVD without needing to extract .VOB from iso file.
    These errors indicate that the image iso is corrupt?
    And no way to change the color of the subtitle?
    Thanks!
  4. Banned
    Feb 2013
    I think that your iso is corrupt.
    You might have to extract the VOBs and then put it thru this program, https://www.videohelp.com/software/DVDVob2Mpg to get a clean mpeg. There is no re-encoding, so no quality loss
  5. Originally Posted by gonca View Post
    But it's on a linux vps, I will extract the vobs and convert to mkv in order to download, are 30 iso and would take months to download everything.
    After downloading will edit the color of subtitles in the MKV with any tool, I see that there are many on the net.
    Thanks!
