Hello,
I have got a lot of movies in the same format :
Video : AVC Main@L3.1
Audio : AAC (LC)
I want to create a blu-ray with a simple menu without having to reencode them all
because reencoding takes a very long time.
Which software can I use?
Thanks per advance for your answers.
You can give multiAVCHD a go, but if your files aren't BR compatible to begin with you'll have to reencode.
Ok, thanks
I will give it a go
What is precisly the compatible format for BR? -
AAC audio isn't allowed in Blu-ray. At the very least, you'll be re-encoding that.
I succeed in encoding my videos so that multiAVCHD does not need to reencode them.
I have started encoding with à 1400kbps bitrate
Is there a minimum bitrate for video for blu-ray disc with a 720*576 resolution?Last edited by mapomme1108; 16th Aug 2015 at 06:03.
is there any software I can use that lets me cut 264L5.2 without reencoding
By BirdDaddie in forum EditingReplies: 3Last Post: 18th Sep 2014, 06:12 -
Best DVD Authoring Software
By mikayd in forum Authoring (DVD)Replies: 22Last Post: 4th Jan 2014, 18:04 -
dvd authoring software
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 04:36 -
authoring software
By anasa in forum Authoring (DVD)Replies: 4Last Post: 31st May 2011, 19:19 -
Need good BD Authoring software
By faramith in forum Authoring (Blu-ray)Replies: 7Last Post: 13th Sep 2010, 21:17
