Greeting!
Actually I want some advises and opinions about my encoding commands, we are using "TS" Raw for detective C anime, and this is are settings commands
or I have to change this commands if I use X265 ?Code:x264-10bit.exe --preset slower --crf 17 --ref 9 --deblock -1:-1 --aq-mode 2 --bframes 8 --subme 11 --psy-rd 0.40:0.20 --qcomp 0.67 --aq-mode 2 --aq-strength 1.2 --fps 24000/1001 --output "700-FE-.mkv"
Regards.
	If you insist in fumbling with a dozen low-level parameters: Yes. Low-level parameters may differ between x264 and x265.
 See: http://x265.readthedocs.org/en/default/
 Try to find some documentation about the high-level parameter "--tune animation". Compare with your choice. Try to understand why the "animation" tuning for cartoons is so different to your set (e.g. uses positive deblocking thresholds, instead of negative as in your choice).
  using the OR command in a batchBy marcorocchini in forum Newbie / General discussionsReplies: 8Last Post: 30th Sep 2014, 18:56
  the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53
  NeoScene command-line encoding - any tricks?By Taapo in forum Video ConversionReplies: 8Last Post: 15th May 2013, 20:04
  MKVMerge Batch Command HelpBy DarrellS in forum Video ConversionReplies: 1Last Post: 31st Oct 2010, 17:05
  Win32 command line WM9 encodingBy temma in forum Video ConversionReplies: 0Last Post: 6th Oct 2010, 21:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
