I want to import multiple videos into Adobe After Effects CC and add the Warp Stabilizing effect to them, and then render them. But i dont want the files to merge into one singel file.. Is this possible?
Create a separate composition (timeline) for each clip.
From this and your other post I'm guessing you have not spent enough time familiarizing yourself with how AE works. There's a lot to take in. Adobe has excellent tutorials on their site.Last edited by smrpix; 13th Aug 2015 at 07:33.
Thanks! Yes i'm pretty New to AE.. I've read some tutorials and watched some youtube videos, but none have explained the issues i had. So thanks. I will look into this
Adobe After Effects CC - How do i downscale videos in size?
By LienFilm in forum Newbie / General discussionsReplies: 6Last Post: 2nd Sep 2015, 10:49 -
Importing h.264 mp4 files into After Effects bug?
By Flynn in forum Newbie / General discussionsReplies: 5Last Post: 21st Feb 2012, 09:17 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
Importing VOBs in Adobe PremierPro CS5
By LiaP in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2010, 14:55 -
Adobe After Effects issue
By Coroni in forum EditingReplies: 3Last Post: 22nd Oct 2010, 20:56
