Hi Guys, I have a bunch of x 264 settings taken from MediaInfo, could someone tell me how I can insert these into MeGUI's x264 settings without having to adjust each setting manually?:
cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.70 / psy_rd=0.60:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=10 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0000 / qcomp=0.70 / qpmin=0:0:0 / qpmax=81:81:81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.80 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Nice, didn't know this one yet. But I do know that it will be a bit elaborate: x264 has high-level and low-level parameters; high-level parameters, for the convenience of the user (typically, "preset" and "tune"), will change a whole set of low-level parameters together. But the information string contains only low-level parameters, and all values no matter if they are defaults. Going from low back to high level will require a comparison between default values and rules of all low-level sets defined by high-level parameters, and the set of low-level results in the string.
MEGUI + x264 settings
By Cunhambebe in forum Video ConversionReplies: 41Last Post: 18th Apr 2014, 06:14 -
Help Me with MeGUI x264 Encoding Settings
By EdsonMarques in forum Newbie / General discussionsReplies: 18Last Post: 5th Dec 2013, 14:47 -
show x264 command line output when using megui as x264 gui
By codemaster in forum Video ConversionReplies: 4Last Post: 12th Mar 2013, 11:35 -
x264 Mediainfo to MeGUI x264 Settings
By shagratt71 in forum Video ConversionReplies: 0Last Post: 1st Jan 2012, 05:59 -
MeGUI & x264 settings
By codemaster in forum DVD RippingReplies: 3Last Post: 17th Feb 2011, 14:07
