    Feb 2011
    Australia
    is there a dvd equivalent to bdinfo? one that can actually give you the same stats as bdinfo does?
    News??? I'm moving you to our dvd authoring section.
    Maybe vobblanker ? It shows titles and pgcs.
    Feb 2011
    Australia
    thats definately not it. i just tried it. im looking for something very similar to bdinfo that when you scan a dvd it will give you all the info on the dvd titles ie, frame rate, runtime, film ratio (1.85, 2.35 etc) audio stats. i kinda want the same stats to show like this picture. Click image for larger version
    okey. I thought you just wanted the playlist information.
    Can't you get pretty good video information video mediainfo? If you choose to open a folder and choose the video_ts folder.
  5. PgcEdit has an Info menu with many informative functions. However, there is nothing that will give you the complete info on the whole DVD. That would be too much.
    For example, here is an extract of the output of Info -> PGCs params and cells table:
    VTST 2:
     ************ VTST 2 , 1   TTN 1  (11:31)  Title 2 ************
     Playback time:  00:11:31.02 (at 25 fps)
     PG Playback mode:  sequential
     PUOs:           0 (0x00000000)
     NextPGCN:       0
     PrevPGCN:       0
     GoUpPGCN:       0
     PGC Still Time: 0
     Audio  track  1 status: 0x00008000 (stream=0)
     BOVs Chap. Prog. Cell  Type  Seam- Ang VOBU  Cell  Cell  Playback     End          Entry    First    Last     Last     VOB Cell
          (PTT)             Flags less      Still Still Cmd.  Time         Time         VOBU     ILVU     VOBU     VOBU     ID  ID
                                  Joint           Time  #                               sector   End      Start    End
     ?    1     1     1     2     no    -   no    3     0     00:00:00.12  00:00:00.12  260760   0        260760   260769   2   1
     ?                2     2     no    -   no    0     0     00:00:37.23  00:00:38.10  0        0        17329    17564    1   1
     ?    2     2     3     8     yes   -   no    0     0     00:04:21.07  00:04:59.17  17565    0        106224   106501   1   2
     ?    3     3     4     8     yes   -   no    0     0     00:03:34.22  00:08:34.14  106502   0        194291   194547   1   3
     ?    4     4     5     8     yes   -   no    0     0     00:02:56.01  00:11:30.15  194548   0        260702   260759   1   4
     ?          5     6     2     no    -   no    0     0     00:00:00.12  00:11:31.02  260760   0        260760   260769   2   1
     VTST 2 total playing time: 00:11:31.02 (at 25 fps)
    r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
    - BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
