When I load a SUP file into SubtitleCreator, I see different timestamps for the same file depending on which file was last opened.
Example:
I open Subpictures_20 PGC.sup.
The first timestamp says:
00:01:36.096
Next, I open a different file, Subpictures_20 VobSub.idx.
00:01:36.029
I then open re-open the first file again, Subpictures_20 PGC.sup.
Now the first timestamp says:
00:01:36.000
What's going on here? How can there possibly be two sets of timestamps for the same file?
Try closing and reopening SubtitleCreator before opening the first file for the second time. If you get the correct timestamp, it's most probably a bug in the software, maybe some variable that isn't properly reinitialized.
"The greatest trick the Devil ever pulled was convincing the world he didn't exist." -
How do I know which timestamp is the correct one?
When I close SubtitleCreator before opening the same file a second time, the timestamp is the same as it is the first time. -
I would bet the correct timestamp is the one you obtain when you open the subtitles right after starting SubtitleCreator. Like I said, it's most likely a variable that isn't correctly reinitialized. But if you really want to know, you can open the subtitles with a different software and compare.
So this is interesting. It looks as though SubtitleCreator does not load the correct timestamps after first launching the program. I tried viewing the SUP in DVDSubEdit, and the only way I can view the same timestamps in SubtitleCreator is by opening the SUP after opening an IDX. Weird.
How to find the timestamps of all cuts of a video
By Danny1 in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2015, 15:49 -
Timestamps are 23 hours off
By ranbo in forum CapturingReplies: 3Last Post: 6th Jun 2014, 16:53 -
timestamps video-container codecs
By Greg79 in forum Video ConversionReplies: 8Last Post: 7th Nov 2012, 15:51 -
Capture DV from Sony Handicam and preserve timestamps
By eswenson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 21Last Post: 3rd Jun 2011, 07:02 -
SubtitleCreator and Windows 7
By sambat in forum SubtitleReplies: 0Last Post: 19th Oct 2010, 11:15
