I had the madVR and LAVfilters folders stored somewhere and i moved them to a different location. I think i was not using those filters anymore, but how can i be certain that files (.ax) were not registered somehow on my system and make sure i wont be having any problems
If you didn't run the uninstallers for those apps, they're info is still in your registry. When you moved their folders, you also moved their uninstallers. The registry has no way of knowing what you did. Take a look at installed programs in Control Panel. If their names are still there, they're in the registry.
- My sister Ann's brother -
They are not installed, i used their folders as portable data. And i just pointed to their files from inside the programs. I tried mpc and i didnt get video after i moved the folders. It seems i am definitely still using the lav filters. Still Not sure for MadVR though
I unregisterd LAV Filters. Moved them to desired location, re-registered, but i dont get video now on mobile videos. Why does LAV splitter send streams to microsoft decoders? I have set LAV Audio and LAV Video to prefer and unchecked all interl filters on mpc
I have registered and not received a code.
By JustanOtheruser in forum ffmpegX general discussionReplies: 8Last Post: 6th Jun 2015, 05:47 -
Error Trying to Login to Registered Users Portal
By vasilemj in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 22nd Aug 2013, 19:04 -
ECC registered memory...Is it worth it?
By OldMedia in forum ComputerReplies: 3Last Post: 9th Sep 2011, 00:38 -
Cannot start registered version
By itsonlyme in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th Jul 2011, 16:06 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 18:27
