Hi
I have a .avi file that i want to convert to a vcd, but the original has a constant hiss sound when playing. To encode i usually use TMPGEnc, with SSRC and TooLAME, for the audio, but they don't rid the hiss.
Has anyone come across a guide or program to get rid of this hiss, or know of any ways to manipulate audio??
Your help is appriciated.
Ryan![]()
Search this board for:
hiss
You'll get a bunch of hits.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Extract the audio track, then download this program called Cool Edit Pro or 2000 from http://www.syntrillium.com. They have filters to remove intermittent pops and in your case, hiss. I've used their software to take out this hiss from Vinyl records, if you get the settings set properly, it'll work very well.
Audio Hiss Problem--I tried audacity
By bbbbbbb45 in forum AudioReplies: 16Last Post: 15th Apr 2012, 09:55 -
Is There a Free Program that Removes Hiss and Pops from WAV files?
By cplevel42 in forum AudioReplies: 10Last Post: 24th Nov 2009, 14:28 -
Audio hiss removal in VirtualDub
By BobAchgill in forum Newbie / General discussionsReplies: 6Last Post: 27th Apr 2009, 09:57 -
'S' letter hiss (not general hiss on idle!) - help needed
By zee944 in forum AudioReplies: 7Last Post: 21st Sep 2008, 05:54 -
audio becomes a hiss
By ballboy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 20th Jul 2007, 00:03
