I had MakeMkv 1.91 working but now after a long pause when I run 1.91 it insists on installing newer version. I installed 1.95 and when I run it immediately the MakeMKVcon64.exe program crashes. Any ideas on how to resolve this? I am running on Windows 8.1.
Can you post windows log crash of MakeMkv?
Does MKV itself create a logfile, and where would that file be created, and what is the approximate filename?
I'm running MakeMKV inside a virtualized environment and apparently the only record of the event in Windows Event Viewer is of the MakeMKV application hanging after the 64-bit sub application crashes.Last edited by pone44; 10th Aug 2015 at 04:02.
Try it again without virtualized environment.
Extraordinary claims require extraordinary evidence -Carl Sagan -
disconnect from the internet
and try 1.91 again
if it can't get to the web, it can't advice you to update
then it should run normal, just as it did before there was a new version
why do people think the PC has to be on the internet ALL the time 24/7
i do lots of things off line
especially my video stuff
i get real tired of being told to update to the newest version of this or that software
if there is a SNAG/problem ..then yeah...but not when its running good, and i don't need the latest new option
MakeMKV Beta
By Arthur_Ballsack in forum Authoring (Blu-ray)Replies: 1Last Post: 21st Jun 2015, 14:25 -
Help with MakeMKV
By DaveG2147 in forum Blu-ray RippingReplies: 3Last Post: 23rd Jan 2015, 12:54 -
MakeMKV problems
By Theo C in forum Authoring (DVD)Replies: 2Last Post: 8th Jan 2013, 10:39 -
makemkv
By maxone71 in forum Blu-ray RippingReplies: 2Last Post: 5th Feb 2011, 06:55 -
Trying to use MakeMKV
By Humbug in forum Blu-ray RippingReplies: 4Last Post: 7th Nov 2010, 09:14
