  1. I bought a cheap IP Cam (easyN brand). It saves video/audio as avi. The only way I can hear audio is if I use the builtin video player that comes with the software. I have tried every player on the planet and don't hear audio. There is a codec in the program's installation directory called avcodec-54.dll so I'm guessing that's the one it's using. I'll attach screenshots from gSpot.
    What can I do to convert this to a format that can be used on a Windows computer?
Name:	8-8-2015 8-03-19 AM.png
    USA
    Gspot is really old (2007). Try MediaInfo and you may get better info about the file and the audio format. I mostly use 'Tree' mode.
    And welcome to our forums.
  3. Thanks. Here's the output... any suggestions?
Name:	8-8-2015 5-45-47 PM.jpg
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Looks like they are using a proprietary format. So their software is your only option.
    Google is your Friend
  5. Thanks. There must be some way I can play it and convert it to another format, no? Is there some utility that let's me manually specify a coded (dll) to play the file, and then output in a new format?
  6. Member Cornucopia's Avatar
    Play with the supplied app, while recording audio using "WYHIWYG" input in sound mixer (to a new app, such as Audacity). Then sync up the V+newA in an NLE.
