Which one of these containers would be best for UHD 4k? AVI, MKV, 3GP or FLV?
Thank you in advance for any help,
yeto
				Results 1 to 10 of 10
	It depends what the scenario is - what compression is used for audio and video (some are incompatible in some containers), and what the target software or hardware is supposed to be
	Such container which records the camera in 4K {MP4 (XAVCS), AVCHD}. Color grading in NLE editor also XAVCS or AVCHD
 http://indianexpress.com/article/technology/gadgets/ces-2015-panasonic-launches-range-...y-disc-player/
 This prototype integrates video processing and optical disc drive technologies making it capable of reproducing 4K (3,840 x 2,160 pixel)/60p[1]/10-bit[2] high resolution video, and supporting the latest technologies such as High Dynamic Range that marks a major leap in the brightness peak from the previous 100 nit3 to 1,000-10,000 nit to improve the power of expression; wide color gamut standard BT.2020[4], which greatly increases color reproduction; high-efficiency video compression technology HEVC (H.265)/ Blu-ray Disc playback at a high bit rate of 100Mbps.
 What kind of miracles? It is very outdated.Last edited by Jamaika; 8th Aug 2015 at 04:34.
	I have some UHD 4k mp4 files/videos that I need to play on a Samsung TV from a flash drive. The Samsung TV will not play the mp4 files. Without knowing what compression is used which container would you try first, second and so on?
 Thanks in advance for any help,
 yeto
	First, I would look in the Samsung TV's manual and see what it supports. Second, I would consider codecs more important than containers so I would use mediainfo to see what I've actually got. Third, if necessary, I would reencode my file into a codec/container combination that the Samsung asks for.
	I agree with smrpix. You can reduce the list of options be verifying what is supported by the TV. This includes the container, codecs AND file specs (ie: resolution, video bitrate, audio, etc.).
 There most often isn't a "best", it's what meets your requirements for use.Google is your Friend
	I converted the file to .ts format which my TV supports. The original .mp4 file was 835 MB in size. The converted .ts file is 255 MB in size. I used Cloud Convert to convert the file. Is it normal for a .ts file to be approx. a third the size of the .mp4 file or did I lose information in the convert process?
 yeto
  Converting containers ... .avi to .tsBy Tafflad in forum Video ConversionReplies: 2Last Post: 18th Oct 2014, 13:03
  WD TV Live and audio sync (lipsync) issues in MP4 and MKV video containersBy moviewatcher666 in forum Video ConversionReplies: 9Last Post: 20th Apr 2014, 18:22
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
  Which containers, DivX, MP4 or MKVBy jamesj84 in forum Video ConversionReplies: 4Last Post: 18th Jan 2012, 14:49
  .MKV Containers?By F22RJ in forum Video ConversionReplies: 6Last Post: 11th Apr 2011, 19:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
