I noticed in half the scenes of my source, the video is quite soft looking and in the other half its quite sharp. It doesn't just randomly changed sharp to soft and back at the same intervals, it does it just about every couple minutes or when a new scene comes up.
I use a sharpener to fix the softer scenes, but then the real sharp ones are far too sharpened.
Is there a smart filter that auto adjusts or a way to get the video to stay about the same sharpness in all scenes or for the length of the video?
Or am I going to have to do it the hard way and specify different sharpness strengths for different frames with a very long script and check every frame in the video to know which frames get what sharpness levels?
No. There is no accurately detect how "sharp" a video is - so you will have to apply different filters manually per scene
Use an edge detector, like mt_edge(), to build a mask. Then use that mask to overlay only where there aren't very sharp edges already. Adjust the threshold values to suit.
MKV back to BDMV, for real?
By Asterra in forum Video ConversionReplies: 7Last Post: 1st Sep 2012, 08:51 -
captured video with hauppauge card... video looks blurry
By granturissimus in forum Capturing and VCRReplies: 4Last Post: 2nd Feb 2011, 07:43 -
Blurry video...
By Delora in forum Video ConversionReplies: 4Last Post: 17th Dec 2010, 12:23 -
blurry video
By drew68 in forum EditingReplies: 0Last Post: 6th Dec 2010, 13:12 -
Blurry video on export
By beckerss19 in forum Video ConversionReplies: 25Last Post: 1st Oct 2010, 14:58
