I use Mac OSX and Toast to burn my VCDs. It used to be that when I dropped an mpeg (VCD ready) on the toast icon, it burned it to VCD and played fine in my Apex AD-800. Now, those discs and ones that I can still make that way are recognized by the 5131 (it says "play" at the top), but I get no a/v. However, SVCD's that popped and hiss in the 800, play beautifully in the 5131. Any mac users out there know how to get these to play? I use GNU vcdtoolsX and if the original is a bin file that toast doesn't like at first, I use vcdXrip then vcdXbuild on the resulting .xml file and burn in Multitrack-XA mode. This process works great only if the bin or mpeg returns an error when dropped on the VCD option of toast. If toast accepts the original bin or mpeg, I get a recognizable but unplayable disc.
Also, even though the manual says that it plays Jpeg slideshow, I have never had a disc I burned play. It may be that I am missing something, but I burned the disc as an ISO-9660 format and even though it sees the jpeg files, it doesn't play them. Any ideas would be great on this also.
Thanks.
Results 1 to 1 of 1
Weird component problem with LG555 and Apex tv...
By dvd mon in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Jan 2011, 14:40 -
Crown ADVDR9000 (Apex DRX-9000 I Think...) Firmware.
By eufemia in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Apr 2009, 10:01 -
Replacement for Apex AD-1500
By siskiou in forum DVD & Blu-ray PlayersReplies: 7Last Post: 30th Mar 2008, 22:59 -
Apex AD1250X Owners?
By nemesys23 in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 17:36 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 11:33
