Hello. I'm sorry for my English
I got stuck on following problem. First i edited video on a tablet (with windows), using avisynth and virtualdub with ffdshow codec. Then i switched to PC, installed the same avisynth, virtualdub and ffdshow as on tablet, copied all the files and when i tried to open the avs file with the result of my previous editing, Virtualdub opened it i think twice larger than the original picture was (so that about half of the image goes out of frame). On tablet the size was ok just as in original files. I have no idea how to resize it back to normal. Please, help!
Try VirtualDub's View/Pane Layout/AutoSize menu. Are you sure it's displying at twice the original resolution? Could it be displaying correctly but it doesn't fit on the monitor due to the monitor's (lower) resolution?
If you're using ffdshow for decoding make sure it's resize filter isn't enabled.
how do i open ffdshow (h264/avc) encoded videos inside avisynth ?
By vhelp in forum Video ConversionReplies: 19Last Post: 31st Jan 2014, 05:27 -
How to use Avisynth videoscopes with realtime video (VirtualDub + ffdshow)
By Brad in forum Capturing and VCRReplies: 7Last Post: 14th Dec 2013, 01:50 -
Avisynth problem with VirtualDub
By shun in forum EditingReplies: 2Last Post: 2nd Sep 2013, 22:31 -
ffdshow virtualdub problem
By Brooke Holloway in forum Video ConversionReplies: 6Last Post: 19th Jun 2013, 17:42 -
Virtualdub / Avisynth problem - stumbling between joined clips
By Sebastian2011 in forum EditingReplies: 32Last Post: 5th Feb 2012, 16:17
