Love to try out this tool, but keep getting "Selected source is not BD format".
The source are ripped files on hdd, I know I need to select the folder that has the BDMV folder, but no luck. Of course I tried other folders just for the sake of it...
I did google the problem, but none of them really help.
Results 1 to 10 of 10
Win 7 x64
i7 , 18GB ram -
Win 7 x64
i7 , 18GB ram -
If you just want to do a main movie backup, AND the movie only has one primary m2ts file instead of being split into many medium sized ones due to seamless branching, you could select that m2ts file in the Streams folder using the File-->Import-->Video file method. If you want the menu and extras, you'd need to import it as has already been shown.
What did you use to remove encryption and rip to the hard drive? The two programs I recommend for this are AnyDVD HD and MakeMKV (as an mkv or the full disc using Backup mode)
You could try ripping with MakeMKV and output to an mkv file. Import this mkv as a video file into BD Rebuilder. Again, you lose menus. -
The BD structure on the HDD might be messed up. Does it play in PDVD or other media software?
Any other suggestions that let me keep menu and no need to re-encode?
Win 7 x64
i7 , 18GB ram -
BD Rebuilder
By kirkmc in forum Blu-ray RippingReplies: 27Last Post: 8th Sep 2013, 01:37 -
bd rebuilder
By joe478 in forum Blu-ray RippingReplies: 4Last Post: 8th Feb 2012, 22:49 -
BD Rebuilder Help
By ceet12 in forum Blu-ray RippingReplies: 17Last Post: 8th Dec 2011, 05:12 -
BD rebuilder and the tools it needs
By Moontrash in forum Blu-ray RippingReplies: 4Last Post: 23rd Dec 2010, 15:56 -
Settings For BD Rebuilder
By B-ry in forum Blu-ray RippingReplies: 22Last Post: 26th Oct 2010, 19:50
