Hello
I'm trying to encode old tv-series dvd that are interlaced to progressive (23,976 fps). I've tried many guide, handbrake settings etc. without any success. Each time the motion aren't smooth as the dvd themselves specially in the high motion action scene.
Could someone point me a guide or few tips on how to achieve this goal?
kalemvar
Welcome.
What does "interlaced to progressive (23,976 fps)" mean? If you're referring to NTSC DVD or standard definition BluRay, they are produced at 29.97fps -- either interlaced 29.97 or progressive with 3:2 pulldown (telecine) for 29.97 playback. Are you saying the DVD's have had pulldown removed and now play at 23.976 progressive? If so, you encode them adding 3:2 pulldown to get 29.97fps.
Many TV shows both old and new started as film (23.976), then telecined (29.97) for broadcast and DVD.
Your profile has no location or PC system info, so I'm assuming NTSC. PAL would be a different story.
Why are you processing the DVDs in handbrake? Do they have problems?- My sister Ann's brother -
If your TV series was shot as film (3 progressive/2 interlaced in every 5-frame cycle) then it can be IVTC'd and Handbrake should be able to do it properly, although I wouldn't use Handbrake for that or anything else.
If your TV series was shot using video cameras (every frame interlaced) then you can deinterlace it but it should be kept as 29.97fps. Trying to make it 23.976fps will mean removing unique frames and it'll play very jerky.
If you don't know how to determine these things or if what LMotlow and I wrote reads as gibberish to you, then please make available a short 10-second sample from the DVD, a sample with steady movement.
frame rate reduction of 29.970 fps to 23.976 fps in megui
By yohanfed in forum Video ConversionReplies: 2Last Post: 28th Jun 2014, 20:15 -
Convert 29.970 fps to 23.976 fps
By ILoveEDM in forum Newbie / General discussionsReplies: 7Last Post: 10th Nov 2013, 18:20 -
23.976 vs 23.972 vs 24 FPS
By Kelinya in forum Software PlayingReplies: 8Last Post: 28th May 2013, 13:03 -
23.976 fps ntsc dvd is possible ?
By ashe09 in forum Newbie / General discussionsReplies: 5Last Post: 11th Jun 2012, 08:35 -
23.976 to 29.97 weird FPS problem
By michcio in forum SubtitleReplies: 10Last Post: 11th Jan 2011, 05:58
