  1. Member golfnut's Avatar
    Sep 2003
    Hi Guys. Just got my Pioneer 2209 installed and am ready to back up my Blu-Ray discs for the kids. I know to use Imgburn to burning, but what softwares do you guys recommend for ripping and shrinking (Freeware If Available and Is Good and Reliable)? Thank you for your help on this.
    Thank You,
    GolfNut
  2. for ripping i would use AnyDVD the Decrypter is free and for shrinking BD Rebuilder..
  3. Member golfnut's Avatar
    Sep 2003
    Thank you Acesn8s, any other recommendations?
    Thank You,
    GolfNut
  4. Member golfnut's Avatar
    Sep 2003
    What is currently the best software for shrinking and ripping plain DVD discs, NOT Blu-Ray Discs.? Thank you.
    Thank You,
    GolfNut
  5. Thank you Acesn8s, any other recommendations?
    no worries mate thats what were here for lol
    backing up retail DVD's their's tons of freeware mate AnyDVD, DVD Decrypter, DVD Shrink, DVDFab HD Decrypter
    DVDFab Passkey.
    actually mate DVD Shrink would be more resourceful for you, as it will do both jobs your looking to to accomplish
  6. I still use DVDShrink for ripping DVDs quite regularly, but it won't handle some of the newer copy protections. If you have trouble ripping with it (the #1 sign is it thinks it needs to output way more files than could fit on the original DVD.... ie 50GB or more) running AnyDVD in the background doing the decrypting should fix it.
