I have WinFF and I am trying to convert an UHD .mp4 file to .ts. I don't see the option to do this. Is there a different extension that would work better for UHD or can I somehow just enter the .ts code? I don't want to lose any resolution if possible. My Tv supports AVI, MKV, ASF, 3GP, MOV, FLV, VRO, VOB, PS, TS AND SVAF.
Thanks in advance for any help,
yeto
No need to convert with ffmeg if your tv supports uhd mkv since all mvkmerge does is remuxes it to another container,the video isn't touched.
BugMagnet: I was going to suggest the Video To Video Converter and just change the container and direct stream copy. However when I experimented with a .mp4 and chained the container to .ts it failed. I do the direct stream process for changing .flv to .mp4 files and it usually works but I suspect it is because the specs are so close to each other. I would imagine Video To Video Converter could convert the files but it would take some time. It does have .ts output option.
I would suggest make a copy of your files and experiment with those in video to video converter. This way you can see if it does what you want and you still have your untouched originals just in case. Video To Video Converter does have a batch mode if that would be helpful but I would just try one or two at first and see how that goes. -
thanks for that tip johns0
sadly it has been abandoned prematurely. Batch processing would have been nice. but it does work and fast. ty
Convert Mp4 (AAC) to MP4 (AC3)
By GreaterMuta in forum Video ConversionReplies: 3Last Post: 4th Oct 2014, 06:32 -
How 2 convert MP4 w/3 audio trax+1 vid trac into MP4 w/1 audio+video trac?
By Whitezombie455 in forum Video ConversionReplies: 11Last Post: 17th Nov 2013, 03:14 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 14:36 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44
