Hi
I am a long time user of Subtitle Workshop but I havenīt taken advantage of its fully potential.
I have mainly used Timings-Delay and Timings-Adujst to synchronize subtitles.
Now comes a situation I cannot really handle.
I would like to copy and paste multiple of lines from another subtitle to fill in the blanks.
The subtitle I am working on doesnīt match the movie which is a director's cut. So instead of just delaying the subs past the extra scenes, I would like to add the original english subs to fill in the blanks.
The extra scenes would have english subs and the rest would be subbed with the desired language.
Adding each line individually would be quite cumbersome....
/Thanks
I don't think you will find any automatic way to add all lines automatically...
You could also try subtitle edit and see if you find any new features. -
If I understand you correctly:
In Subtitle Edit: Rigth click -> Insert subtitle after this line.
If the subtitle file inserted don't have the rigth time codes, high ligth them, rigth click and select a sync method.
I don't know for SW.
MKV w/SSA/ASS soft subs to MP4 w/hard subs using Format Factory
By Budman1 in forum Latest Video NewsReplies: 0Last Post: 13th Oct 2012, 00:59 -
Add subs to existing authored DVD/Keep original Menus?
By louv68 in forum Authoring (DVD)Replies: 4Last Post: 19th Feb 2012, 19:56 -
mkv to avi with original subs
By tekkai in forum Video ConversionReplies: 6Last Post: 28th Jan 2012, 03:21 -
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20 -
Adding subs.
By Ytrix in forum SubtitleReplies: 2Last Post: 21st Oct 2010, 12:39
