  1. Hi, I've been having an issue with MPC. The volume control if used by the scroll wheel on the mouse is extremely buggy since I installed Windows 10. Sometimes the scrolling works to change sound levels and sometimes it does not. It even gets reversed, scroll up to lower the sounds and the opposite, completely backwards. In fullscreen mode it doesn't work at all unless I put my mouse on the sound bar in the corner. Not really a huge problem but its really annoying because i've been using this forever and now it doesn't work. I tried installing different versions of MPC but its the same now for all of them. Any thoughts?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Yes. Another Win10 bug.
    Google is your Friend
  3. Try MPC-HC and get the 64 version for Win 10. Post back here if that works or not.
    Extraordinary claims require extraordinary evidence -Carl Sagan
